Stalling on low rpm & in park - No Codes
I've read through a lot of posts regarding similar issues, and am running out of ideas.
Situation: Truck starts and idles fine cold. Once it's warmed up it periodically stalls when coming to a stop and will stutter (if not stall) when put in park. It will immediately start back up no problem. It throws no codes.
Attempted Solutions: I have cleaned the MAF, removed & cleaned the the throttle body, replaced (a very dirty) air filter. I am replacing the fuel filter tomorrow. The fuel pump driver module looks fine but will replace to be sure. I do have a fram oil filter and will swap out to a different brand at next change.
Truck Details: 2006 F150 SCrew Lariat 4X4, 5.4L. No engine mods.
Changed the fuel filter & reset the PCM. So far so good, just a 15min drive after so far so we will see.
I waited the 2 hours and disconnected the pump, ran it until stalled and gave it some extra cranks... I still stink of gas. But hey, if it works, I'm willing to stink for a little bit.
Out of curiosity, could the A/C cause rough idle/ stalling? No probs today, but no A/C, everytime I've had a problem the A/C has been on.
K so no longer 'so far so good'. I was hoping giving it a good drive would help it figure things out, but it stalled out coming to a stop tonight. I am about to leave for 2 months and will replace the fuel pump control module when I return. I may just go ahead and replace the throttle body as well.
I have noticed that the power steering seems a little wonky. It's a little rough and kind of tight. I had a power steering issue previous and it messed with the rpm's and general engine performance. There doesn't seem to be a leak, the fluid level is fine, I will do a check of the PS system tomorrow, any ideas where to start looking?
Thanks for all the help so far!
i had stalling issues with my truck twice. the first time was the throttle positioning sensor and the second time was a broken fuel pump/sending unit. mine threw codes both times though. does the check engine light come on when it stalls and go away when you crank it, or just not come on at all?
I'm also going to check for a vacuum leak.
Things just got worse. I went out to pick up a new pcv just incase. Went to 2 different places neither have a part number listed. Apparently it might be a OEM product only. Lame. By the time i left the last parts store the truck was having some major problems. It started stalling anytime my foot was not on the gas. Didn't matter what speed I was going... I got off the highway quick.
I was trying to eliminate the small stuff and work my way up the dollar ladder. Now I think I'll just replace the fuel pump driver module and throttle body. Any other ideas... I'm currently sitting in fast food joint letting thetruck cool down. :{
After I got home I took some video and sound clips of the engine.
Audio of engine running 'normally':
http://www.youtube.com/watch?v=gonSCrjz1dY
And video when rough idle, but no stall.
http://www.youtube.com/watch?v=o1ljxDrokAo
Hopefully it will help with ideas. The fact that it continually gets worse the longer it drives makes me think air/ fuel... but I'm at a loss.
I agree about the throttle body, I was hoping to replace the gasket and tps today, but all my part vendors have to order it in.... So I have to wait 2 months, as I will be away.
