Puddle Light Wire Question ?
Old Jun 12, 2010 | 10:38 AM
Rodneys's Avatar
Hello, I got my new Telescoping Towing Mirrors installed the other day. When I had my door panel off , I did have to move the 9 to 8 Pins so that that Mirror Defrost Button would stop blinking,,Thats all good and works fine. I was wondering if I had the correct puddle wire already in there, I have a total of 8 wires wires,,,
Green/purple stripe
Black
Yellow
Purple
Green
Yellow
White/Blue stripe
Black
Old Jun 12, 2010 | 10:48 AM
NCSU_05_FX4's Avatar
I believe the white/blue is the wire that triggers the door lights, that's probably the one you want... Hang on a sec and lemme check...
- NCSU
Edited to add... My mistake, I was thinking of the wires under the step plate. The BLACK/YELLOW and BLACK/PINK wires are what I tapped into when installing my AMP steps.
Old Jun 12, 2010 | 01:06 PM
Rodneys's Avatar
So you think I don't have the wire up at the mirror,,I'm going to have to tap into the sill plate....right
Old Jun 12, 2010 | 06:31 PM
W.L.B's Avatar
You will need to pull one of the pins that is no longer used (I think I used 11 IIRC) and connect a wire to it. Then run a wire through the door and tap into a wire in the kick panel thing. It has the diamond plate looking stuff on it. It is black with pink I believe. You will also need to run a wire from the passenger side to the driver side.
Old Jun 12, 2010 | 07:26 PM
Rodneys's Avatar
Ok,,i was hopeing I already had the right wire,,,thanks alot
Old Jun 12, 2010 | 07:54 PM
W.L.B's Avatar
Nope, not a 2004 you wont. The puddle lamps didnt come out till 2007 or 2008. After you get them working you need to replace them with LED's. They are SO much brighter and look awesome.
Old Jun 13, 2010 | 09:37 AM
Rodneys's Avatar
Thanks alot ,,I 'll change them out also,
Old Jun 13, 2010 | 10:22 AM
rednoved's Avatar
Have you done the LED swap on your puddles yet? It was a PITA when I did it, but it was worth it. It looks great.
Old Jun 13, 2010 | 10:26 AM
W.L.B's Avatar
Yeah I did mine about a week ago. I went to harbor freight and bought a mini hack saw. It worked amazing. And only cost $3. I tried for hours with a razor blade and couldnt get anywhere. I used the brightest LED's that V-LED had and they work perfectly.
On a side note i also figured out that you can wire up a viper alarm to turn on your interior lights when you unlock the truck. So now when I unlock my truck my puddle lamps kick on.
Old Jun 13, 2010 | 12:20 PM
subcooled's Avatar
https://www.f150online.com/forums/ar...t-circuit.html
Old Jun 13, 2010 | 04:25 PM
rednoved's Avatar
That would be cool. I have a Clifford alarm on my truck. I don't really care for the way it is setup with the interior/cargo/puddle lights. I would like the alarm to work like the factory fob controlled the lights. When I unlock the truck, interior lights come on, and when I lock the truck, the lights instantly dim. Right now the lights don't come on when I unarm the truck, and when I arm the truck, the lights take a while before they dim.
Old May 23, 2012 | 01:12 PM
sam1947's Avatar
I realize this a old thread, but just wanted to up-date it a bit (this may be here already, but didn't find it). Just installed an Ebay set of towing mirrors http://www.ebay.com/itm/ws/eBayISAPI...m=120914132467 into my 07. Went to upgrade the puddle lamp and got a surprise. The lens just pops out as before, however, the bulb which is a 194 in this unit is mounted on a rubber 'plug type' of connector. So long story short, these Taiwanese light are easy to change the puddle lamp to LED's..no cutting or anything..very simple and easy.
