Test: Spark Plug Removal using Impact Wrench
#61
I finished removing the plugs using the 3/8 battery impact wrench. First 5 no problem. Then the 6th and 8th broke. I think where I screwed up was not keeping the engine warm. I did the left side which was no problem, then only ran the engine for about 5 min before I did the right side. Should have warmed it up longer.
I did make a video on removing them. I'll post it soon. If I did them again, I'd use the same method, because its the easiest. If they break, so what. The extractor takes them out in 15 min anyway.
I'm convinced that if a plug is going to break, a plug is going to break. Using that tool to fish the broken plug out, you have to turn the extractor a few times before the broken plug pops out. They are really stuck in there. I don't think any amount of carbon cleaner, or PB Blaster or anything would have prevented the plug from coming out in one piece.
#63
Nice work! Cant wait to see the video. Im going to use a cordless impact also. Any tips or observations you made while doing the removal you can give me, to help me in removing my plugs would be great. The weather is getting real nice now and im going to tackle this very soon.
#66
#67
I just went to have my plugs out got a quote from a dealer for 400 plus 300 for every one they break. I took it to another place that would do it for 350 flat rate so i took it there. They soaked the truck overnight and couldnt get a single one of the plugs to turn. They said if they tried any harder they knew they would break off. Now my truck is rougher than ever and throwing codes. They told me cleaner must have soaked in and to just drive it hard this weekend and burn it out. Does this sound right? Truck has 60k miles and its really disappointing. sorry i had to rant.
#68
#69
It is my understanding that the sleeve becomes wedged into the head due to the carbon deposits on the electrode sleeve. The hole in the head is too small to accommodate the sleeve with the carbon deposit and it just sticks and the two metal parts of the plug separate as the threaded part is removed. The only actual breakage involved may be porcelain.
#70
#72
It is hard to believe that there are dealers out there that don't know anymore about what they are doing than that. Pretty sad. They should charge you no more than a 1/2 hour of labor for each broken plug. If they did not break the plug lose how did the cleaner get down in the combustion chamber? They probably messed up a COP or a boot.
#73
How much damage am i doing or could I be doing by driving with my one plug obviously misfiring. Will it need to be changed now for sure? My Gryphon says its misfiring and cylinder 2 is one causing it. I might just try to get a lisle tool and go at it myself but I need it done ASAP because I use my truck every day.
#74
OK I'm in to find out what happens with this. My Brother is a Ford tech, only for a couple years though. He doesn't have the bias opinion of them, just change em out he said, didn't see too worried about it. I only have 46k on them though....
As for the Anti-Sieze on there, I believe they have a specific type they want you using....
Has anyone tried using some Sea-foam or water try and burn off some carbon first?
#75
