Spark plug pics
Old 02-18-2010, 09:27 PM
Fred06FX4's Avatar
Spark plug pics
Just had mine changed at the dealership, 49,000 miles.
Pretty obvious why my truck was misfiring so bad.
Old 02-18-2010, 09:32 PM
All in one piece. Those plug gaps look pretty large.
Old 02-18-2010, 09:38 PM
MGDfan's Avatar
Hello! how are y'all doing tonite?
OP - that's great! Thanks for sharing those pix!
Mr. Stealth! Dang, sir, you have a great pair of optical feeler guages!
Cheers & Bests!
MGD v2.1d
Old 02-18-2010, 09:57 PM
You have no idea.
Old 02-19-2010, 07:33 AM
Fred06FX4's Avatar
Yes all in one piece. I was very impressed considering some of the horror stories I had heard in here. Would have charged me $40/plug if any broke and that was my biggest concern taking it in.
The second plug in from the left has so much stuff built up on it I suspect that may have been the culprit along with the large gaps also.
Old 02-19-2010, 08:17 AM
bdholsin's Avatar
Since I haven't done the change I can't get my head around exactly where the plugs are breaking. Any chance you can show me or describe it in the picture above? I curious.
Old 02-19-2010, 10:05 AM
The part that has the deposits in the image separate from the next piece with the threads. The hole in the head for the electrode shield is too close a tolerence when the deposits are on it, and upon removal it sometimes separates from the rest of the plug.
Old 02-19-2010, 10:16 AM
If you are not, I would suggest buying gas that has a good detergent, such as Texaco, Shell, and Chevron.
Old 02-19-2010, 11:32 AM
2004f1505.4x4's Avatar
glad you got them changed, my dealer broke half of mine
Old 02-19-2010, 11:39 AM
azmidget91's Avatar
mine look way worse then that
Old 02-19-2010, 11:53 AM
How many miles? Mine had 65,500 and did not look near that bad.
Old 02-19-2010, 11:30 PM
Fred06FX4's Avatar
I think the only gas station out of those three we have here are shell....have started using BP though, says it is recommended on the gas cap. Is BP gas any good or does Ford just get a kickback from BP for putting it on there?
Old 02-20-2010, 03:50 AM
glc is offline
BP is not "top tier" gas but it's good gas. However, BP owns Arco and that's garbage.
Old 02-20-2010, 10:03 AM
Mr. eXtreme's Avatar
Sounds like this is my problem. Off and on mine will stumble while jumping on it...
have 65, 5xx on the truck
Old 02-20-2010, 10:36 AM
Hal65ford's Avatar
dang looks like i should consider changing my plugs and im at 65k
Quick Reply: Spark plug pics
