Last second help before I buy!!!
Old Nov 19, 2009 | 08:12 PM
Cuz's Avatar
Cuz
I am wanting just a little bit of lift in the front of my new (new to me) 2006 F150 XLT 4x4. I do NOT want to be higher in the front than the rear though. So I was thinking of going with this 1" Daystar kit. Just to add a little more of that 4x4 look to my new ride.
Can anyone tell me any reason why I should not or should go with this 1" kit??
Thanks for any help fellas. This sight has been great to me in the short time I've been a member!
http://www.daystarweb.com/productdet...?productID=151
Old Nov 19, 2009 | 08:16 PM
ride_002000's Avatar
I have a 2.5" front spacer on my FX4 and it sits about a half inch lower in the front than rear. I would suggest a 2" Hell Bent Steel spacer or an AutoSpring spacer
Old Nov 19, 2009 | 08:18 PM
4x4wolf's Avatar
I would go at least a 2" kit
Old Nov 19, 2009 | 08:19 PM
Go with an AS 1 1/2" spacer.
Old Nov 19, 2009 | 08:29 PM
mdhawkin's Avatar
at least 1.5" if not 2". I honestly think after you go through the work of only adding one inch you may leave yourself wanting more. If you are still not sure you can always go measure your front fender hight from the ground then use a floor jack to raise the truck 1" then 1.5" then 2" see what you like the most.
Old Nov 19, 2009 | 08:57 PM
yetti96's Avatar
Is it a a regular, scab, or screw?
I say 1 1/2" AS because when I put a 2" AS on my truck it raised the front about 2 1/2". Weird how that works.
Old Nov 19, 2009 | 09:27 PM
bridge's Avatar
I've got a 2"' Auto Spring on mine and it is perfect. A 1" will still have a slight rake.
Old Nov 19, 2009 | 09:39 PM
ryanralston07's Avatar
http://cgi.ebay.com/ebaymotors/AUTO-...Q5fAccessories
Old Nov 19, 2009 | 09:42 PM
mdhawkin's Avatar
That does bring up a good point, below is an excerpt from a post I did a while back discussing spacer thickness. Looks like AS may be a little larger than others. From what I have discovered and AS 2" = Hellbent 2.5".
Originally Posted by FOXrace99 View Post
does anyone know the actual thickness of the 2.5" AS? I have a Rize and it is an actual 2.5" thickness, but it sits way too high and the suspension angles are ridiculous. I just ordered the HBS 2.5" to replace it and its actual thickness is 1.625".
Originally Posted by MDHawkin View Post
The autospring measures as follows:
Spacer Size / Total Lift
1 5/8...............2"
1 11/16............2.5"
1 3/4...............3"
This means the 2.5 HBS = the 2 AS....
[/QUOTE]
Old Nov 19, 2009 | 10:13 PM
Carolinaboy32's Avatar
So is AS or HBS better? I want to add a leveling kit on mine and put a airbag in the rear so it doesn't get the ghetto lean when i tow.. What would be best?
Old Nov 19, 2009 | 10:17 PM
mdhawkin's Avatar
This is probably one of those six of one half a dozen of another answers. They both have great reviews. I have the 2.5" AS and love it, very well built. If you get an AS make sure you get the powder coated version (advertised as PC)
Old Nov 19, 2009 | 11:33 PM
Green2005's Avatar
I have a 2in AS powdercoated...its really about what you want! Decisions, decisions!
Old Nov 20, 2009 | 03:41 AM
Cuz's Avatar
Cuz
Will this actually work like that? Just jack it up to where I want it then buy a leveling kit that is about 1/2" shorter?
STUPID NEXT QUESTION: Where should I place the jack to get just the body to lift like it will with a level kit, without damaging the truck that is?:o
Again, I'm brand new to this truck and to lifting/leveling trucks at all...
Old Nov 20, 2009 | 03:42 AM
Cuz's Avatar
Cuz
Originally Posted by yetti96
is it a a regular, scab, or screw?
screw xlt
