what is with the calipers on these 04-08 trucks
It is not the slides, If you live a road salt area and do not wash the chassis very often the pistons will stick. Just replace rear disc calipers on a 2001 Expedition. I am surprise you could not detect it before it got that hot. You should have felt the affected sticking caliper during a low speed application of the brake.
May not be your caliper that is the problem, especially since you have changed it 4 times or so.....
The rubber brake line to the caliper is most likely your problem, sometimes the inner hose is defective or worn out and will colapse internally and not let the caliper bleed off properly....have seen this many times before on other vehicles....
