what is with the calipers on these 04-08 trucks
Today my 4th and final caliper that hasn't been replaced finally started sticking...what is with these garbage calipers?, I never had to put them on my ranger in 105k,after tommorow, all of mine will have been replaced before 73k. This last one made the rotor so hot that it melted my center cap and it fell off,now I'm sol because the 178's are discontinued. Has anyone had this many issues? And where should I go about getting centercaps? I want new wheels but not this soon
You are the first I have seen with that problem! That is really strange. There were some early 2004s that had smaller calipers. They started using larger calipers at some point. I wonder if that might calculate into your problem. The wheels made for the earlier 2004s would not clear the larger calipers that were later used.
I bet it has something to do with it because I have a different pn than 05's...they are garbage.I never ride the brakes, I'm easy on my truck.
About a month ago my left front was siezing, I replaced both fronts with rebuilds. 2004 with 65000kms.
There were 3 different listings in the book for my year, 2 of them didn't match, 1 was out of stock so we went up to 2005 and that was a perfect match.
I don't know if it's possible but you may want to look at converting to the larger calipers, if the problem continues. That is, if you can confirm that is the problem.
And too, I've seen more rusty/corroded/seized caliper slides as of late than I have failed calipers.
