gonna be doing a center shift swap
Old Mar 9, 2009 | 11:56 PM
Same here. Its got me thinking... paint the dash a darker grey and paint the trim & vents silver, FX4 leather... i'd be happy.
Old Mar 10, 2009 | 12:11 AM
ATOM's Avatar
Originally Posted by pylda
ATOM...you are making me seriously think about this now...damn you!
you know you want to, i wish it was an option in the xlt, but it's not. i love my chrome and gray, i wanted to buy a mark lt because i could get center shift, chrome and gray. but i can't see working with a mark lt, but i can see it rolling 35's on 20's. the swap should be a piece of cake. i am searching for some graphite plastic dye for the dash when it arrives, gonna have all the parts in transit by tomorrow.
start piecing it together and in time you will have the whole thing. i see pics of molding the console angle to the dash, pretty doable with some time and glass. i bought a console off ebay the other day for almost nothing and i'm pumped to get this mother in
Old Mar 10, 2009 | 12:22 AM
pylda's Avatar
Will you make a parts list and do your own full write up? Pretty please...
Old Mar 10, 2009 | 12:39 AM
ATOM's Avatar
i might be able to write something up. i got the wiring colors figured out already. just take the rest of the dash out is pretty simple. maybe a 3hr job
Old Mar 10, 2009 | 12:59 AM
ATOM's Avatar
unhook the red plug, these 2 wires will need to be lengthened and run down to the console
tan/white stripe--will attach to the 7 plug off the console
red/yellow stripe--" " " "
note that the wires are the same colors as on the console harness
(i stole the pic from FX4andHarley's gallery)
now look at pic #2, that plug is what your after containing 2 blacks, pink with light green stripe, and yellow
both ground go together and length it down to the console--attach to the black on the console harness
pink/light green attaches to the console harness, it detects if your foot is on the brake before shift (when you hear that click)
yellow runs down to the console also key removal inhibit solenoid (no idea what that means)
now you will need to snag an illumination wire from somewhere, back of the radio or something (i am going that way, as i had a tap in there for my leds anyways)
when you get the jump seat out take the, hook the positive side of the cig lighter and hook that to the purple orange (or i am just gonna leave that harness and use that plug in and pull the pin outta the connector)
you will need 2 floor mounting brackets
front-4L3Z-15045B32-AA
rear-4L3Z-15045B34-AA
and i think i will need a new shifter cable also, i am gonna call and find out if there is more than 1 shifter cable used in the 07 f150's. i can't see ford using 2 but maybe 1 is longer than the other
Old Mar 10, 2009 | 09:33 AM
I think it looks ok.
However, why spend all the money on it when you really can't shift with it...?
At least I've got a real center shift... and I didn't have to swap nuttin'.
Old Mar 10, 2009 | 09:50 AM
stx2006's Avatar
You can shift with it.
Old Mar 10, 2009 | 10:23 AM
Yup. But only once, into that big D.
Well, you do indeed got 2 and 1... but the last time I tried doing a launch while manually shifting an automatic, it grenaded the transmission.
(Unless I was doing it wrong... :o Maybe there's a hidden third pedal mod too... hmm)
Old Mar 10, 2009 | 02:27 PM
whaler417's Avatar
You will need a new shift cable. The center console is longer.
Old Mar 10, 2009 | 02:31 PM
ATOM's Avatar
did you run into any issues doing your swap?
did you use the same hole that the truck had for the column shifter to route the new cable thru?
Old Mar 10, 2009 | 06:29 PM
ATOM's Avatar
i just bought a complete dash assembly this morning, paid 250 shipped for it. out of a 05 lariat, silver and tan. will be parting out everything i don't need (vents, all tan pieces, lariat cluster, etc.) should be able to make some cash and cut down on outta pocket $$
got both trim panels on the floor and the front console mount, 58 bucks shipped
new shifter cable, rear console brackets will be here thursday at the dealer.
still up in the air on colors though.....
Old Mar 10, 2009 | 07:17 PM
bigdog87's Avatar
ATOM, how much would you charge to come take a visit to Alabama and do it for me?
Old Mar 10, 2009 | 08:04 PM
blackjack8900's Avatar
How about mine too??
Maybe we can get a group rate
Old Mar 10, 2009 | 08:25 PM
ATOM's Avatar
it's easy and i'm cheap....lol
Old Mar 10, 2009 | 08:45 PM
bjp207's Avatar
id probly stick with grey atom...what are you going to do about the steering column? do they make them grey with no hole for the shifter?
