Bed Liner Torx Bit Size ?
Better off to just tape off around it and be very careful.
The tailgate "F-150" badge is on w/ 3M sticky, there are two alignment pins so that the highly skilled UAW member gets it on straight. Yes, that means that there are two holes in your tailgate. If you want to remove it, simply use a heat gun or your wife/girlfriend/side ho's blow dryer warm the emblem and work from one side and lift it off. Some folks use dental floss or fishing line and saw back and forth the cut through the 3M sticky. WD 40 works good for removing the left over sticky goo. Most quailty supply stores sell the 3M sticky in different sizes if you are inclined to put it back on.
