05' GURU's Opinions PLEASE! MAJOR ISSUES.
Old Jan 11, 2009 | 08:51 PM
Ritch's Avatar
I've posted before with other ?'s
I was going to trade in my 05' F-150 5.4 a monnth ago or so, but my wife insisted I keep it. I've got 50k on it now. A month ago I had my #8 plug broke off, had new plugs and a coil put in. Ran fine until the other day.
My truck shutters real bad and the check engine light blinks. And the occational demming of lights. Took it to a family mechanic and he told me I need to take it to Ford to have them put it on a Ford computer. Anyone with some help it would be greatly appreciated.
Old Jan 11, 2009 | 08:58 PM
brownchristian's Avatar
Flashing CEL means misfire. Mine did the same and resulted in a stuck injector which resulted in a new engine. All covered under the extended warranty offered by Ford for the injectors.
Old Jan 12, 2009 | 09:46 AM
faawrenchbndr's Avatar
What brand plugs?
Old Jan 12, 2009 | 11:01 AM
DaMoose81's Avatar
yeah, sounds like its either a spark plug, wire, or a fuel injector
Old Jan 12, 2009 | 11:03 AM
Rockpick's Avatar
Moderator &
Nearly an IDENTICAL symptom to how it felt/looked when my injectors went out.
Old Jan 12, 2009 | 11:46 AM
2stroked's Avatar
I've got to ask. How does a spark plug just break off? Answer: They don't - unless something causes them to break. So, unless you were trying to replace your plugs (a nightmare on '04-'05's) or an injector stuck and hydrolocked the engine ...
Like RP said, get it to a dealer. Your warranty has been extended for injector problems and you may just get to check it out.
Old Jan 12, 2009 | 01:21 PM
Sounds like an injector issue. If it is it may be covered under the 2005 extended injector coverage.
Old Jan 12, 2009 | 05:06 PM
Ritch's Avatar
Thanks for the input. Did Ford extend the warranty on the injectors or did I need an extended warranty? I didn't purchase an extended warranty.
Old Jan 12, 2009 | 06:19 PM
Ford Extended the warranty.
