Problems installing LED 3rd light
Old Dec 3, 2008 | 12:11 AM
thenewbreed's Avatar
I removed my OEM 3rd brake light today to install the APC LED 3rd brake light. The OEM has three bulb sockets but the LED has one plug and it does not fit any of the OEM sockets. Am I missing something, I thought these were plug and play.
Old Dec 3, 2008 | 02:47 AM
You need to pull the harness out more. There is a plug in there that you disconnect from the harness with the stock 3 ends and plug in the new light.
Old Dec 3, 2008 | 02:53 AM
jessiebouc's Avatar
When I changed out my light this summer, I had to remove the 2 plastic retainers at the rear of the headliner to reach the factory harness plug. I unplugged the factory light, and replaced it with the new led light. The new light plugged into the factory harness.
Old Dec 3, 2008 | 03:12 AM
This thread has pics, in the 2nd one you can see the clip that holds the excess harness that you need to pull through some more to unhook the light harness from. I didn't have to pull the headliner down any, I just popped the plastic clip out and pulled the harness through some so I could hook up the new light. Clear as mud?
https://www.f150online.com/forums/20...placement.html
Old Dec 3, 2008 | 11:27 AM
Stealth, great link thanks.
Thanks guys for all the info
Old Dec 3, 2008 | 02:43 PM
Wow. 5 minute job. That was easy. I went in through the top. Got some pliers and yanked out the piece of crap plastic grommet holding it in. And there it was just waiting for my LED's.Thanks again
Old Dec 4, 2008 | 04:44 PM
MmmBuckles's Avatar
is this the same for a 1998 f150? im trying to install mine now and it has the same little harness on it.
Old Dec 4, 2008 | 09:42 PM
nuclearthreat54's Avatar
Yeah, you dont need to pull down the liner at all, just break those clips and pull through.
