Third Brake Light replacement
just unplug the old one and plug the new one in ,just for info its a pain in the *** to get to ,its to the left when u unscrew the old third brake light,me and my brother installed mine and i cut my hand to **** lol
its kinda far in so just reach in farther and when u finally do feel it ,it has one of those plastic pressure screws that u will probably have to break off in order to pull the connector alittle bit out to get it disconnected
they can kiss my *** when they call it plug and play lol
Originally Posted by Smokefan
Do you pull on the lighting wire to expose it, cause I stuck my fingers and there and just felt more wiring?
http://www.youtube.com/watch?v=mHadilpTDwc
Originally Posted by LovetheTide
Go into the truck and remove the headliner, or just pull it down some. The attachment you need is not one of the lights you are looking at but is further down the wiring you see.
There are two plug like looking things on either side of the headliner near the rear glass. Don't worry about breaking them but just pull them out and then pull the headliner down. I did most of it just by feel then got the headliner all straight and put those plugs back in.
