I fixed my poor A/C performance
Old Jun 17, 2008 | 02:20 PM
risupercrewman's Avatar
How bout those Pics Dude!..........
Old Jun 17, 2008 | 02:45 PM
i.ride.suzuki's Avatar
pics or didn't happen.
Old Jun 17, 2008 | 02:50 PM
There are only 2 hoses - inlet and outlet. To figure out which is inlet, fire it up and turn the heater on full blast. The hotter of the 2 is the inlet.
Old Jun 17, 2008 | 03:05 PM
BigMan's Avatar
I was thinking about this and I dont think it could work unless I am understanding this wrong.
How does cutting off hot coolant from flowing through the heater core make the air come out of the vents cooler? You said it yourself the heater core radiats heat into the cab (but not through the vents). From what I understand you are stopping the heat from the core but the air coming from the vents is not affected by this. Even if the heater core is hot and running when the A/C is on the air isnt passing through the heater core therefor stopping the heater core from gettign hot isnt going to cool off the air any more than it already is.
I may be wrong here but thats the way I see it.
Old Jun 17, 2008 | 03:07 PM
BtownFord's Avatar
And even if the heater core was putting off heat ingot the cabin the air should still blow the same temperature right at the vents. Correct?
Old Jun 17, 2008 | 03:09 PM
Unless if it's possibly on max and it is sucking the air to be cooled from near the heater core and then not having time or ability to get it as cold if hot water is circulating thru the core.
Old Jun 17, 2008 | 03:40 PM
BigMan's Avatar
where does the recirculating air get sucked in anyways? This would solve our little dilema here. I dotn think the OP is going to get back on here. He must not be a regular.
Old Jun 17, 2008 | 03:45 PM
azmidget91's Avatar
Originally Posted by alomar
Man im still cruising in Phoenix with all 4 windows down and A/C off. Cowboy up!
Then again I had all 4 windows down all winter too, even at night when it was coldest.
Oh well, thats just me. A/C in my truck has been on 3 times since I got it last August :lol
thats because your a wanna be mexican
Old Jun 17, 2008 | 03:59 PM
Spoongooner's Avatar
OK OK ... heres a Pic....
its the Blue handled ball valve inline on inlet heater hose..... Ive since then removed the blue handle from valve... for looks...
the reason it works... is because the heater core and the A./C core?.. are seperated by a cheap a$$ thin piece of plastic... (diverter door)... the heat is so hot it is bleeding though ...
go stand in your kitchen with the oven on... and see how good a/c in your kitchen works.???/
this nocked 10 degress off temp coming out of my vents...
[/IMG]
Old Jun 17, 2008 | 04:13 PM
Ok, that makes sense. Thanks for the pic!
Old Jun 17, 2008 | 04:15 PM
Back to a question I had. Do you think not having coolant circulating might cause damage to the heater core? Maybe even contribute to stopping up?
Old Jun 17, 2008 | 04:16 PM
BigMan's Avatar
isnt the A/C core the thing on the front end of the truck that looks like a radiator? And the heater core should be behond the engine on the cab side. Correct?
Old Jun 17, 2008 | 04:21 PM
The heater core is inside the big black plastic box, under the dash on the passenger side.
That thing in the front is the air conditioner condenser
Old Jun 17, 2008 | 04:55 PM
Lol
Old Jun 17, 2008 | 04:59 PM
knighj1's Avatar
anyone else try this? Mine is plenty cool, but I could always go cooler here in the South
