High Capacity Trany Pan
Old Jun 16, 2008 | 08:48 AM
BigCanuckTruck's Avatar
I've been told it'll drop my fluid temp by 50. Has anyone put one of theses on and are they worth the money? Any recommendations on where to order from.
Old Jun 16, 2008 | 11:26 AM
luckythirteen13's Avatar
not sure how much the temp will drop but it will run cooler. another benefit would be a drain hole. most aftermarket tranny pans have oil drain holes making oil changes much easier
Old Jun 16, 2008 | 11:53 AM
i.ride.suzuki's Avatar
Full of ****.
Get a Powerstroke transmission cooler and remove the inline t-stat if you really want to drop temps.
Old Jun 16, 2008 | 12:17 PM
MercedesTech's Avatar
The MagHytech deep pan is pretty darn good. I think it added something like 7 more quarts or so. Its been awhile, but I like it fine. Don't have temp guage tho, can't tell ya how much the temp dropped.
Old Jun 16, 2008 | 02:52 PM
Josiah's Avatar
Where is the inline t-stat located for the tranny and where is the one for the coolant? I'd like to change both as I'm running hot on everything out at pismo.
Old Jun 16, 2008 | 04:28 PM
Ryanmc86's Avatar
im also interested in where the inline t stat is. mercedes tech where did you get your magna tech pan from?
Old Jun 16, 2008 | 04:47 PM
I have yet to play with my thermastats... so i'll have ta look into that one for ya guys, sorry.
Got my pan from Josh. 1-866-922-0093 ext 107. Tell him your a member here, and that I sent ya his way and he'll give ya a good price on it.
Old Jun 16, 2008 | 06:45 PM
openclasspro#11's Avatar
Originally Posted by i.ride.suzuki
Full of ****.
35 degrees drop after i went to amsoil fluid with a mag hytec deep pan[+10 qt]
Old Jun 17, 2008 | 10:00 PM
countyboy04's Avatar
I was going to ask the same question myself. I have also been interested in swaping it out.
Old Jun 24, 2008 | 10:49 AM
thedave's Avatar
bump for the thermostat, that sounds interesting.
Old Jun 24, 2008 | 11:06 AM
FX4 Matt's Avatar
Registered User
You should run on the beacch in 4 low that helps me keep my temps lower while on the sand
Old Jun 24, 2008 | 11:15 AM
T-stat the block that is inline to the cooler next to the transmission.
4Low is WAY to slow at pismo.
Old Jun 24, 2008 | 09:13 PM
Is there a lower temp thermostat that it could be replaced with?
Old Jun 25, 2008 | 03:32 AM
Josiah's Avatar
http://www.atiperformanceproducts.co...ranscooler.htm
That could possibly be one, if they're inline they should be relatively universal.
Old Jun 25, 2008 | 11:13 AM
180 is what it currently is, you can modify it, but you have to make it forced open.
