Cracks in Akebono Pads
Old Jun 23, 2008 | 03:50 PM
swhite005's Avatar
I bought Akebono Ceramic Brake Pads in February 2007 (ACT1011 and ACT1012). I've had squeal for last few months and finally got the time to take a look at the pads. The front pads have several cracks on the pads which I believe is causing the squeal. I contacted Rockauto (I purchased the pads from them) and they told me the warranty was 30 DAYS! I'm pretty surprised, does this sound right? I can't get ahold of Akebono Corp to verify. If this is correct, I WOULD NOT RECOMMEND THESE PADS.
Old Jun 23, 2008 | 08:13 PM
cva-59's Avatar
Akebono Brake pads
You can reach them 270-234-5500 they are located in Kentucky.
Old Jun 24, 2008 | 03:21 AM
Josiah's Avatar
Let me know how this works out. I have had these pads on for at least 25k miles and not a squeak yet.
Old Jun 24, 2008 | 08:35 PM
LariatRocks's Avatar
Sounds like your calipers are sticking...Did you lube the slides when you replaced the pads?
Old Jun 25, 2008 | 12:17 AM
khendrix2374's Avatar
I bought Akebono pads at about 5K miles and havn't had a lick of trouble out of them yet. 48K miles on the clock.
The truck brakes quietly and quickly. And, the front puts off less dust than the rear.
Mine may be craked too.. I don't know.
Old Jun 25, 2008 | 03:48 AM
swhite005's Avatar
Yeah, I lubed the caliper bolts when I changed the pads. I never had the rotors turned, would that cause the pads to crack? I haven't had a chance to call Akebono yet to see if they'll cover them under warranty.
Is it better to have the rotors turned then install the new pads or install the new pads then have the rotors turned?
Old Jun 25, 2008 | 08:39 AM
Personally, I always have my rotors trued and cleaned (turned) before I throw new pads on. I was asking if you lubed the slides because it sounds like they are sticking (getting hot) and then you had to use them pretty hard, so they cracked. That's been my experience with cracked pads. Or they went underwater when they were really hot.
Old Jun 25, 2008 | 02:03 PM
swhite005's Avatar
I contacted Akebono and they are calling their product development department. Akebono said they will probably issue me new brake pads, but they have to make some calls first. I'll keep you posted and give you the info just in case someone else has the same problem.
