Ford parts tells me no locking gas cap available!
on
I've had a couple customers with locking gas caps lose their keys to the cap. If you know what you're doing, it takes all of about 20 seconds to break a locking gas cap. And besides, there's a screen at the bottom of the filler neck so fuel can't be siphoned out.
If I were a crook, I'd either cut the plastic filler tube and stick a siphon hose directly into the tank, or cut a hole in the bottom of the fuel tank. Remember, your gas tank is plastic...cut, drill on it all day, there'll be no Wile E. Coyote type exploits.
MythBusters did an episode on things added to gas and their effect on an engine. Strangely enough sugar didn't do anything at all. Mothballs boosted the idle and bleach killed it (oxidizes the steel in the tank and sent rust in to the engine).
also I added the locking gas cap to our website if you type in the part number from earlier in the thread it will come up.
[QUOTE=TascaFordParts;3204113]MythBusters did an episode on things added to gas and their effect on an engine. Strangely enough sugar didn't do anything at all. Mothballs boosted the idle and bleach killed it (oxidizes the steel in the tank and sent rust in to the engine). Quote]
Man I always watch MythBusters... how did I miss that one
