s/c on a 05 5.4
s/c on a 05 5.4
what is stoping me from putting a 99-03 lighting supercharger on my my 05 na 5.4 do i just need all the parts or is stuff different also if i do need parts what would they be i looked under the supercharged section of the fourms but i cant find anything on new body style n/a's just on 99-03 trucks so any help would be appreciated thanks yall
I am pretty sure the intake on the Lightning blower 99-04 set-up will not work on the new 3 valve heads 04-09. You would need to go aftermarket set-up IE Whipple, Roush, Saleen, Magnacharger etc.. Beat me to it...
because they are still expensive to some people, also i would say he said it sucks because im guessing he found a great deal on a lightning sc, and would be cheaper(if it would just bolt on) then a new sc
Yea that does suck it wont swap over, however the 3v headers are better for making power, so once you can afford a supercharger, youll probably put out more power then a stock lightning. But the weight is what holds you back.
A 2004 Lightning weighs in at 4670 lbs.
A 2008 Standard Cab regular box 2WD 5.4 weighs in at around 4700 lbs.
ya i found a compleat kit for 400 every kit i have found made by aa company was 2000 or more and in my case ill make more power but my wieght will be the factor last time i got weighed at 5700 and it was on 37's not 40's
Just because it does not fit on your truck, does not mean you can't make a deal work in your favor.
