40s on 6''+3''+2.5''?
Old Feb 26, 2008 | 11:43 PM
specialblends27's Avatar
would a set of 40s work on a 6'' procomp with 2.5'' spacer and a 3'' body lift.. i have 4'' deaver packs in the back so i know the rear wont be a problem. but i dunno if the front would rub real bad or what.. anyone have any suggestions on whether or not 40s will work or should i get some 38s. becuase my 37s are way to small.
Old Feb 26, 2008 | 11:47 PM
tnsilverfx4's Avatar
Will they fit with all that? Yes with trimming I think you could fit them under there. Markmayes has 39.5's on his truck. Ask him what his setup is.
You are pushing it on your front end though.
Old Feb 27, 2008 | 12:01 AM
TonkaTruck33's Avatar
ur gonna need some stronger tierods ends and some aftermarket upper control arms with 40's
Old Feb 27, 2008 | 12:20 AM
and where might i find those?
Old Feb 27, 2008 | 12:26 AM
http://www.chaosfab.com/80501.html
or
http://www.camburg.com/04F150.html
Old Feb 27, 2008 | 01:44 AM
luckythirteen13's Avatar
is this a 2 or 4wd truck?
i would not put a 2.5" spacer on top of the 6" spacer that comes with the procomp kit. get the fabtech if you want to run a spacer on the lift
Old Feb 27, 2008 | 02:30 AM
Josiah's Avatar
You will be fine. If not you will find a way to make it all work, it won't be hard even if you rub.
Old Feb 27, 2008 | 02:33 AM
FX4REACTION1's Avatar
Josiah, don't you know a guy running that setup?
I believe he has a grey f150 on 40's. How's his truck holding up?
Old Feb 27, 2008 | 09:59 AM
Tonka did you run any sort of special tie rod setup on "Old Tonka"?
Old Feb 27, 2008 | 04:36 PM
MercedesTech's Avatar
Yes you can fit those tires with that set-up. Like Josiah said, you may need to do some trimming, but if you really want it, you can make it work.
Your also going to need a re-gear if you haven't already.
Old Feb 27, 2008 | 05:11 PM
jlstang351's Avatar
Or You can buy the 12" rize kit to run 40's
Old Feb 27, 2008 | 05:23 PM
specialblends: Since you have a ProComp lift (I do too) I would suggest you get some MX6 Coilovers or Dirt Logic coilovers to go with that body lift. Thats what I will end up doing.Do you already have the stacked spacer setup?
I can only see the stacked spacers along with 40's making your truck ride unbearable. It will cost you, but I think you would enjoy your truck alot more in the long run.
Old Feb 28, 2008 | 12:09 AM
if i could find the right price for some mx-6 or the dirtlogics i would buy them right now.. or if i could at least find them.. anyone got a website where i could get one of them off of? or josiah do you have anymore layin around lol
yes i have the spacer stacked right now.. ride isnt to great even with 37s but the deaver springs are like clouds. i am eventually gonna get 4.88s but i drive to much highway miles right now and wouldnt be able to break them in.
Old Feb 28, 2008 | 10:12 AM
Well that gives me a reason to look at some deavers.....
You only have to keep the gears under 65 for the first 100miles.
Let me know how hard the Body lift install is. I want to tackle that but I keep hearing scary stories.....
Old Feb 28, 2008 | 01:45 PM
jlstang351's Avatar
I thought gears required no break in period
