Telescoping trailer towing mirrors finally on
Old Aug 13, 2009 | 01:05 AM
  #376
06SCrewyCDN's Avatar
So if I read the thread correctly all I need to do for my '06 is move the ground wire from the 8th possition to the 9th. I'm going camping this weekend so I'll mess with it at the site. I'll post how it works out. Thanks to all that offered insight into this project.
Old Aug 13, 2009 | 09:32 AM
  #377
labman1014's Avatar
Originally Posted by labman1014
for the grounds, you should have 3 grounds right now if u have power, heat, and turn. ford used a ground for each option. pins 2, 9, and 11
the new mirrors all share a ground somewhere hidden in the mirror and moved it to pin 8.
basically ford swapped pin 8 and 11 in the different years. in the 04-06, pin 8 was dome and pin 11 was ground......in 07-09, pin 8 is ground and pin 11 is dome.
what i did was move either pin 2 or 9 to pin 8. you should not have anything in the pin 8 slot now, if you do let me know...it means u already have the wiring for dome. then i would cut the wire in pin 11 about 4 inches past the cennector and tap that wire into the dome wire under the drivers door seal.
do the same for each mirror and u will be good to go!!!
here is my quote from the last page....i think u have it backwards!!
Old Aug 13, 2009 | 08:19 PM
  #378
Yup I think you're correct there... thanks.
Old Aug 15, 2009 | 10:45 AM
  #379
jrbhc8's Avatar
Originally Posted by blackjack8900
The pins are in the connectors that are inside the doors that the mirrors plug into. I don't have a part number for the pins as I took one of them with me and showed it to the guy behind the counter and he gave me a small baggie with 8 and there was no part number on the bag....if it helps here is some info on the connector itself....
Connector:
C521
Description:
EXTERIOR REAR VIEW
MIRROR, DRIVER SIDE
Harness:
14A005/14631
Base Part #:
17682
If you want give me your email and I can email you the diagrams I have.
Does anyone know where to find these connectors. I went to Ford, O'Reilly, KOI, and Radio Shack this morning looking for these. Also look on McMaster-Carr with no luck. Or can I steal some the connectors off my ground wires since Ford went from a 3 ground system to a 1 ground system?
Old Aug 19, 2009 | 03:11 PM
  #380
risupercrewman's Avatar
Just got me some of those!
I just ordered up the TT Mirrors with the Chrome Skull Caps, Electric, Puddle lamp, & heated.......from www.tascaparts.com ! They should be in tommorrow, & they are gonna install them for me!......
The more I have seen them on the roads, the more they grew on me!......
Old Aug 19, 2009 | 04:56 PM
  #381
jrbhc8's Avatar
Nice, you will feel like your truck deserves a little more space on the road once you get those on. Be sure to post up some pics!!
jrbhc8
Old Aug 19, 2009 | 05:39 PM
  #382
labman1014's Avatar
yours should be very easy, just plug and play!!! how much they charging you??
Old Aug 19, 2009 | 06:24 PM
  #383
The mirrors were $ 170.21 a piece + about $180.00 for installation, no shipping since I live down the road from them........
Old Aug 19, 2009 | 06:43 PM
  #384
jrbhc8
Will do!..........
Old Aug 19, 2009 | 07:53 PM
  #385
f22a's Avatar
Wanted to share my experience. My truck is an 04 XLT (Built 11/03), power mirrors with no signals/head/puddles. All of the posts said to switch the 8 & 9 pin, but my truck did not have a #8 pin - the only ground was pin #2. I moved the #2 ground to #8 and they worked like a charm.
Also, as far as the pins go, between all of the pins Ford has used over the years, the dealer seriously had a tool box filled with about 250 different sizes. Having no specific part number, I just took the pin that I cut off of the #2 ground in there and matched them up - took five minutes maximum.
Crappy cell phone shot:
Hope that comes in handy for someone.
Old Aug 19, 2009 | 09:40 PM
  #386
labman1014's Avatar
Originally Posted by f22a
Wanted to share my experience. My truck is an 04 XLT (Built 11/03), power mirrors with no signals/head/puddles. All of the posts said to switch the 8 & 9 pin, but my truck did not have a #8 pin - the only ground was pin #2. I moved the #2 ground to #9 and they worked like a charm.
did you really move it to #9? #9 is the exterior rear view mirror signal for the 07-08 mirror. #8 is where it should go. it is the slot on the top right as u look at the connector with the tab on the right. #9 is the lower left as u look at the connector with the tab on the right. i just dont want to confuse ppl here. you only had one ground because you only had one option on your OEM mirrors.
Old Aug 19, 2009 | 09:42 PM
  #387
labman1014's Avatar
dang, wish i lived closer to you...i would love to make $180 an hour!!! just messing with ya. to each their own....some dont have the time to do stuff like that.....
Old Aug 20, 2009 | 07:01 AM
  #388
pdabbs911's Avatar
When I go to www.tascaparts.com the drop down menu for Ford replacement body parts does not have F150 as a choice??? Any reason why? Thanks for the help.
Old Aug 20, 2009 | 08:48 AM
  #389
If you lived closer, I'd hire you!...........
Old Aug 20, 2009 | 09:41 AM
  #390
Krohbar's Avatar
I thought I'd post a few pics of the mirrors from inside.
