Telescoping trailer towing mirrors finally on
I just placed an order for a set as well. I am still confused about moving the ground. I have an 04 with power, signals, and heat. So my mirror now has two grounds but the new mirrors have 1 ground. Do I splice the current two grounds from my old mirror together then connect them to the new mirror. I am sure I am making this more complicated then it needs to be.
Are the wiring diagrams from Tascas website all i need to figure this out. I understand pretty well how to run the puddle wire off the dome lights.
jrbhc8
jrbhc8
it should go to pin 8 which is the only ground in the new mirrors.....
jrbhc8
jrbhc8
the new mirrors all share a ground somewhere hidden in the mirror and moved it to pin 8.
basically ford swapped pin 8 and 11 in the different years. in the 04-06, pin 8 was dome and pin 11 was ground......in 07-09, pin 8 is ground and pin 11 is dome.
what i did was move either pin 2 or 9 to pin 8. you should not have anything in the pin 8 slot now, if you do let me know...it means u already have the wiring for dome. then i would cut the wire in pin 11 about 4 inches past the cennector and tap that wire into the dome wire under the drivers door seal.
do the same for each mirror and u will be good to go!!!
thanks Lab. Got corn-fused.
And Tasca, how about the part # for the pins?? I'd love to order some so I can properly attach the puddle lamp wire. Some guys are just cutting off the wire, but I'd like the pins that fit that connector.
Measures, get this, 16" from the passenger window. 16.5" from the drivers window.
With factory mirrors I get 13'' at bottom of window 15" at where the window starts to angle.
Heater button light blinking
Hey guys! So its been about a month since I put my TT Mirrors on and I love them! I just noticed, however that when I turn my turn signals on, the little light on the heat button blinks at the same tempo!!! Im not sure if I want to dive into it and fix it yet, mostly cause I'm tired of taking my door apart. When I installed them I just plugged and played. I'm thinking it's happening because I didnt move any wires around, right? Ground problem maybe?
~ Brian
I have factory heat w/button, signals and power. I just installed my mirrors from Tasca and it all went well except I have the exact same problem with the blinking dash light. Then after a few minutes of driving my mirror signals quit working. I think this is related to a timer on the heat button switch. I haven't altered any wiring as I thought it safer to see what the original plug would do first. Labman, great advice on this thread, you didn't utilize the heated mirror option? Has anyone resolved this issue?
~ Brian
~ Brian
Thats what I figured. I started thinking about it, when I was changing out my head unit, and had the heat button disconnected, the blinkers didnt work. I figured the old ground is crossed with the new heat button...or something like that. I will eventually fix this, but I'm tired of taking my door apart. At first, when I was trying to figure out the pin thing, I spent about 30 minutes looking at it like a retard. Can someone post a how to video on youTube?
07 and 08 are wired like the mirrors and r plug and play!!
~ Brian
~ Brian
