Accesort fuse and CB Radio install???
Hey guys I am hooking up a CB radio to my truck and it says to connect the hot wire to an accesory fuse spot on the box...well I found and open spot that isnt being used and put the hot line into it and the CB fires up but my problem is getting the hot wire to stay in that position it is very loose and easily pulled out...How can I get it to stay?
Thanks guys
Thanks guys
Thanks guys
Thanks guys
.02 cents worth, but thats about all its worth anyways.
Well thanks for the info guys...I wired it in with the hazards so I can always get juice to it...great idea until I leave it on one day and drain the battery...as for the HAM radio...I didnt want to hassle with going through the firewall... I like old school and just want to listen mostly so I dont need some fancy schmansy radio that I will never do anything with..i'll take my 50 dollar cobra
there is already a hole predrilled and caped in the 04+ f150 fire wall just remove the plug slide it threw and run it to the battery, its not going to actually drain your battery if you leave it on over night. it take .12 amps or so to run a cb the average battery has .3 to .5 in parasitic (misspelled but in a hurry) drain on it already.
Why not a direct connection to the battery? AFAIK the best way to do any types of RF communication is directly connected to the battery to avoid a lot of interference off the truck.
Just my HAM radio license stuff I learned and my $0.02...
