Need cluster reprogramed!
Old Aug 2, 2007 | 10:02 AM
mitch150's Avatar
Just left a rant on the Quality Is Job 1 thread on this subject. I want to buy a lariat cluster for my '05 xl 150 but can't find a dealer to program it for me. I'm trying to find a dealer before I buy one so I don't waste any money on a cluster that sits on the shelf collecting dust. Anyone have any suggestions. I feel like I'm SCREWED! Any input would be appreciated. Thanks!
Old Aug 2, 2007 | 06:01 PM
tmd07's Avatar
Hey mitch150.... I may be of some help. I will leave you an email or private message.
Old Aug 3, 2007 | 04:20 AM
mitch150's Avatar
Thanks tmd.I want that cluster.
Old Aug 3, 2007 | 06:53 PM
AceSC's Avatar
Hey I got a ROUSH cluster for my 04. I need it programmed too. It's still sitting in my closet in its ROUSH PERFORMANCE box. How about sending some help my way too? Hehe, if I can't get the mileage programed on that cluster I will probably have to sell it.
Old Aug 4, 2007 | 01:30 AM
HotBlue05SCREW's Avatar
What color bezel is that ? Gray ? PM me if its gray please
Old Aug 4, 2007 | 08:52 PM
tmd07's Avatar
I will send you a pm or email...
Old Aug 5, 2007 | 03:30 AM
Piccolo's Avatar
If you are tossing around helpful information about programming please throw some info my way as well.
e-mail address is matthew_spitz@hotmail.com
Have a lariat cluster sitting on my shelf collecting dust as well as the message center switch, but I do need to find the part number for the wire harness to hook it up.
Old Aug 5, 2007 | 03:52 AM
tmd07's Avatar
I will send you the guys info in your email....also the wiring pigtail for the message center switch is WPT586. I get all my stuff from www.getfordparts.com If you put in that WPT586 in the part# search it will come up with the price etc..
Old Aug 30, 2007 | 09:32 AM
mitch150's Avatar
Wiring diagram?
Ok, I have the cluster, the message center switch and the plug w/ pig tails. Anyone have the wiring diagram to where the pigtails are connected to my wire harness? There's 6 wires altogether but I thought there was only 2. Can anyone help. Thanks! Oh yeah, do I have to order a new bezel? Or can I just cut the new switch into my bezel?
Old Sep 1, 2007 | 08:52 AM
mitch150's Avatar
Question Anyone??
No one out there has any answers? Which forum should I search?
Old Sep 8, 2007 | 06:55 AM
mitch150's Avatar
Hey tmd07
Hey tmd, and anyone else out there. Thought I'd post an update.Got the cluster in and works good (after having it programmed). Haven't done the message center switch yet as I'm waiting on a little info abuot the bezel and wiring.
Old Sep 8, 2007 | 07:54 AM
Bootleg837's Avatar
why cant you post the info here instead of email so we all can see it
Old Sep 9, 2007 | 11:48 AM
tmd07's Avatar
Hey there. Glad it all worked out for you. As far as the switch goes, The one I showed in the previous posts, I cut that in myself. I used a hole-saw to drill out the ends round and then cut out the middle with a hack saw blade. Just be careful because there isn't much room for error or it will show. I will post a pic of the hole I cut and a wiring diagram shortly.
Old Sep 9, 2007 | 12:12 PM
tmd07's Avatar
Here is a picture of the hole that I cut out. Just measure the switch CAREFULLY. I actually cut it out a little small at first on purpose and used a file to finish it up so it wouldn't be too big. I believe the hole-saw was a 7/8" but don't quote me on that. Also when I first installed the switch, it was tight and the buttons actually got stuck in when I pushed them so I had to file it some more. Also you can see I had to file notches to accept the switch tabs. Good luck! Will post a wiring diagram next.
Old Sep 9, 2007 | 01:43 PM
mitch150's Avatar
Hey tmd, thanks for the cluster and info. Also just to let you, I did not use your guy to have the cluster reprogrammed. Had it done locally.Going to do the switches later this week.
