Safe to tow with rear bumper?
Your bumper should have a weight rating on it. I would use that rating to see if you can tow the Jeep or not. I certainly wouldn't significantly exceed that rating though; a failure could easily lead to loss-of-life out on the highway. And if you do exceed the rating, and it fails, then all the responsibility (both morally and legally) would fall on you. On the other hand, if you were within the ratings, and it failed, then you could argue that it was a manufacturer defect that cause the failure, and therefore that the manufacturer should bare the responsibility... I always think in terms of "what if" situation. I personally don't want to be responsible for any tradegy as a result of my doings...
Originally Posted by 05F1FIDDY4x4
Is it safe to tow with the rear bumper on my 05 4.6 4x4? Reason I ask, is because my nephew is giving me his old 88 Jeep Cherokee but it does not run.(motor locked up). I dont have a trailer hitch, Would it mess anything up if I was to tow it on the bumper?
Just not worth it. Those cherokees weigh in at 3200-3400 lbs then add 1500 for the trailer and your sneaking up on 5k. Waay too muc IMO for a bumper pull. Invest 100 in the hitch and just do it right. I know it is more expensive but the peace of mind and knowing your not tearing up a nice truck is worth it
