twin 57mm throttle body adapter 90% finished
Old Jul 6, 2007 | 10:05 PM
assasinator's Avatar
there is three angles of the finished product. i roughed it and painted it to match my car.
all that is left is the IAC, a bracket for the throttle cable, and a few ports for vacuum.
-bill
dyno in the next month.
Old Jul 6, 2007 | 10:11 PM
Black 2000's Avatar
Bill,
Looking good! Are you doing before and after dyno's?
Later...
Bruce
Old Jul 6, 2007 | 11:16 PM
the before dyno is the one posted in my sig. this dyno will only have the intake changed. i will also mod a stocker with inlet porting only and dyno that. that will give numbers for the average guy who wants a little more power without extensive work.
Old Jul 7, 2007 | 11:36 AM
Black 2000's Avatar
That will be great and I look forward to seeing the results.
Later...
Bruce
Old Jul 25, 2007 | 08:58 PM
here is a link to the installation i am doing.
http://forums.wildhorsesclub.com/showthread.php?t=19118
Old Jul 26, 2007 | 02:10 AM
Josiah's Avatar
your butterflys appear cable operated, I thought they were electronic in the new 5.4. Did you get rid of the electronic flybywire?
Old Jul 26, 2007 | 09:24 PM
yes, but it can be done with drive by wire simply with a 05+ mustang gt TB.
the throttle response is simply amazing. no claims here, but it runs like i always hoped it would. it revvs so quick i really can't goose it wide open and stay off of the rev limiter. look at todays finished pics.
i have a road beside my house that's a little over a quater mile, i ran up to 110 in that stretch. it's hard to quantify it. dyno soon of course.
i guarantee it has enough power to feel. the motor is breathing fully now. i will say your trucks have a better inlet than the one i took off. so the improvement may not be as much for a truck. it has to be better with a lrger opening into the manifold.
i am going to madison KY to pick up another N/A manifold. i am going to do a stage less than what i did here to it. just open the inlet even larger. i am going to epoxy and cut it to 90mm. add some plenum volume. or something. i am really not sure exactly how i am going to mod it. lets see what the dyno says before i touch it. if i get 325 - 335 rwtq then the argument of losing torque is not valid. i expect 288+ rwhp. i don't have long tube headers.
Old Jul 27, 2007 | 08:41 AM
Black 2000's Avatar
Looking good!
Later...
Bruce
Old Oct 31, 2007 | 09:05 AM
ok i finally went to the track with exactly the same setup as this spring with the twin 57 on it. conditions were pretty much identical. 72 degrees RH 68%.
03/30/2007: 60'-2.1028 330'-5.9690 594'-8.56 1/8th-9.1520 @ 77.29mph
10/30/2007: 60'-2.1030 330'-5.8930 594'-8.44 1/8th-9.0109 @ 79.09mph
i have to lift for the 2-3 shift to avoid the limiter so the mph is off. with a program fix i expect 2 mph more
