Aftermarket throttle body 5.4l 3v
Old May 12, 2007 | 03:16 PM
thetruck's Avatar
What are the advantages of an aftermarket throttle body? I found this for the 5.4l 3v. Would it be worth it?
http://www.jusnesmodified.com/store/...roducts_id=507
Old May 12, 2007 | 03:26 PM
05RedFX4's Avatar
I was told that the stock throttle body is larger than the 75 mm BBK unit, so if that is true, you would actually lose airflow and H.P.
Old May 12, 2007 | 06:08 PM
nuclearthreat54's Avatar
???????? Told by who?
Old May 12, 2007 | 07:06 PM
FX4 Matt's Avatar
Registered User
The last Dyno day I went to a guy there asked Mike about an aftermarket throttle body he said it works better as a paper weight / noise maker
Old May 12, 2007 | 09:08 PM
ParkM's Avatar
Are you sure he wasn't talking about the spacer? If I'm not mistaken the stock throttle body is 70mm not 75,
Old May 12, 2007 | 09:24 PM
Black3v's Avatar
Exactly! These things are horrible to tune for and I have heard horror stories from the '05+ Mustang crowd. The F150's are basically the same TB but a different shape and the gears are inferior to the stock pieces. There have been a few cases of them sticking open which would automatically turn me away! Its just not like the good ol 5.0 days anymore.
Old May 12, 2007 | 09:28 PM
05RedFX4's Avatar
Mike Troyer. When I ordered my tunes, I was going to put a BBK 75mm TB on and I asked Mike to write that into the tunes, he told me not to waste my money on it, that the stock one was bigger.
Old May 13, 2007 | 12:56 AM
Man thats wack, why would they sell those? Those money hungry animalistic devil worshipers!
Old May 13, 2007 | 03:23 AM
azmidget91's Avatar
ill let you know as soon as i get mine from bob at jusnesmodified.com he and alot of others have said i should see a decent increase, then im gonna datalog with the xcal2 and get a few more ponies out of it since that will be the last of the bolt ons
Old May 13, 2007 | 05:39 PM
05RedFX4's Avatar
After thinking about it, I went out and pulled my stock throttle body off and measured it, and as it turns out, the narrowest point is at the blade, kinda like a venturi. It's wide at the top, narrows at the blade, then widens again before the manifold. The measurements are 3.23" or 82 mm at the top, 2.95" or 75 mm at the blade, and 3.04" or 77 mm at the base. I would guess that all 3v 5.4's have the same TB, but mine is an 07. Now if the BBK unit is a straight 75 mm,then I would rather keep my stock TB.
Old May 13, 2007 | 07:49 PM
04gtf150's Avatar
glad you measured yours, I was about to go out an measure mine. Now the question is y would an aftermarket company sell a throttle body that is the same size, or smaller than a stock one???
no one may ever know
Old May 13, 2007 | 09:32 PM
azmidget91's Avatar
like i said mine shipped out last friday so ill compare them when i get it hopefully the begining of the week
Old May 13, 2007 | 10:35 PM
MGDfan's Avatar
Ummm... because there's one born every minute? Actually, the way it's going I think that stat needs to be updated to say 'every 30 seconds'.
Old May 13, 2007 | 11:21 PM
anaheim_drew's Avatar
All because kondoms are harder to get than beer.
How about a dyno run before you install your BBK.?
You have said that a JLT/XCAL and straight pipe is better than other available setups.
You have it why not dyno and post before and after results instead of others taking the word of you and your butt dyno?
Old May 14, 2007 | 04:07 AM
azmidget91's Avatar
i have a friend with a dyno and i have to pick up a door from his shop in the next week or two and ill ask to use it
