Is this leveling kit any good please help
Old Apr 28, 2007 | 10:56 AM
hmfic's Avatar
Originally Posted by f150newf
Ok,
is this the only reason not to use the 3" that the rear will be lower? I am planning on putting an AAL in the rear....so, I can go with that right>
Depends.. Is it a 3" block now, or is it a smaller block that will net you close to 3" lift like the autospring 2.5". Before you buy, I would call and get the actual size of the block. If it is a 3" block right now, that is too much lift for your front suspension like the balljoints and possibly the cv joints. Might even have alignment problems.
Even when I had the skyjacker 3" kit in my '05, it netted me an 1/8 inch left LESS than the 2.5" Autospring.
OR,
just buy the autospring, which you KNOW is recommended by hundreds of people on here and save yourself a few $$$..
Old Apr 28, 2007 | 11:03 AM
Tylus's Avatar
why do you want to run an AAL? yes, the 3" will make her sit front up until an AAL is installed. You can fit 35" tires with the stock rear-end right now. The front also, but they will rub on full turn and while articulating offroad.
edit: I meant to say you can fit 35" tires on all 4 corners once the 2.5" spacer is installed.
Old Apr 28, 2007 | 09:34 PM
xlint1's Avatar
I have an 04 2WD with the 2.5" leveling kit (Ebay) that sits on top of the coilover. I will be taking mine off, b/c I'm getting poor tire wear and the front end sits up a little higher than the rear. I DO NOT like the way the upper control arm contacts the spring when raised off the ground. It seems like it's forcing the front end to be something it's not. Like body roll in turns I never had before the leveling kit. And the mech. that did the alignment, said one of my adjustments was WAY out. I'll prob drop the rear to level it now.
Old Apr 29, 2007 | 04:34 PM
Tylus's Avatar
I am assuming you have the spacer leveling kit. I hope you don't have the kit where the coil-over is taken apart. That is very bad kit and it does break stuff, and affect ride quality.
1. what brand of spacer do you have?
2. If you're getting bad tire wear, it means you either have P rated tires and/or that your alignment is not correct
3. an improperly designed spacer kit will cause your control arm to contact the coil-over spring. that is why the offset Autosprings spacer is the best on the market.
4. the leveling kit will have no affect on your body roll. at all. the spring rate is never affected since you don't take the coil-over apart. Did you re-install the front swaybar?
5. for a spacer kit, the alignment specs will be off the same amount from side to side. all this kit does is push the toe in. you aren't even aligning the tires for straightness, just for an even contact patch.
it sounds like you bought a cheap POS leveling kit. and whoever did you alignment didn't do it properly.
Old Apr 29, 2007 | 04:36 PM
Tylus's Avatar
oh yeah, I meant to say I've got the 2.5" Autosprings spacer kit. My upper control arm DOES NOT contact the coil-over spring. In addition, my tires are wearing very evenly. Nor was my ride quality affected. There is no additional body roll.
I've seen posts where guys have had the exact same kit for 50,000+ miles without any issue at all.
Old May 1, 2007 | 01:41 AM
xlint1's Avatar
Glad you're happy with yours, mine is not the offset style. It didn't require seperating the coilovers, not sure of the name brand. I've had it for about 1 yr, and the alignment was always fine. I just noticed the tires are getting erratic wear on the "corners" of the tires after removing the winter ones. It appears to be more like a bad shock wear (59k mi) or front end parts going bad. I'm surprised you didn't notice any type of body roll increase, (yes I installed the front sway bar WITH poly bushings) since raising the front end also raises the center of gravity for the truck. Anyway, I'm glad you like yours, maybe it's just the brand difference but mine will be coming off and looking into dropping the rears to level it now.
Old May 1, 2007 | 02:43 AM
Tylus's Avatar
you shouldn't have much if any extra body roll. the center of gravity will only raise about 1".
You're not doing much suspension wise. I didn't think of the shocks, but that seems to be your most likely culprit. I'd still say your alignment needs checked.
Old May 1, 2007 | 07:40 AM
f150newf's Avatar
So, If I do get this spacer, adding an add a leaf will net me about 1" in the rear as well...so she should level out again nicely and not affect my front suspension to much right?
Old May 1, 2007 | 09:24 AM
Dupuis's Avatar
Looking at the Autospring 2 1/2'' front lift also. How many of you installed it? Was it hard. Tools used?
Old May 1, 2007 | 01:12 PM
PHS79's Avatar
An AAL will get you about 1.5-2" of lift, so you will end up about 1" higher in the rear +/- alittle. Another route that you could go if you are just wanting to raise the rear up a little bit it to put air bags under the rear end. I did this and I am very happy, with 20psi in the bags it raised the back about 3/4" and with 1500lbs of patio blocks in the bed on sunday it sat just about dead level. I pumped them up to 40 psi and it raised the rear 3/8" past level.
Old May 1, 2007 | 01:15 PM
PHS79's Avatar
I didn't do mine since I was very busy at work when I get it, but the mechanic that did mine said that it was very easy. I wish that I could have done it myself, and would have, but I didn't want to wait a month to do it, so I just paid him 140 to do it and the alignment.
Old May 1, 2007 | 03:34 PM
Tylus's Avatar
took <3 hours with basic handtools. I did have to go buy a 30mm socket though. the Autosprings instructions tell you exactly what tools you will need and exactly how to do it.
very easy to install.
Old May 7, 2007 | 02:30 AM
swishbish33's Avatar
Sorry to thread-jack, but out of curiosity, for an 05 Screw 5.4L 4x2, is the 2" enough to have it sit dead even or is the 2.5" needed? Seems to be conflicting opinions...
Thanks!
Old May 7, 2007 | 03:09 AM
freekyFX4's Avatar
I personally will never use another Autospring product after the way I was treated by their "Customer (lack of) Service". It looks like something that a person made in his garage. The paint was still wet on mine when I got them. I had the 2.5" Autospring on my '04 F150 and it was fine until I added heavier wheels and tires. After that, the upper control arm would hit the coil spring any time I would drive over a sharp drop, like a speed bump. When I complained, I was basically told to go screw myself and it started a huge ugly thread on this site. No Autospring for me...never again!
Old May 7, 2007 | 04:48 PM
Tylus's Avatar
so were you one of the reasons why they have started the offset spacer now?
you can't get one of those "old" style spacers from them anymore. looks like you were a victim of R&D on the road
I've had my tires fully stuff and fully drooped since the install. there has not been any contact or noise. as long as you get the offset spacer, you're fine.
