LED Center Console Mod
Originally Posted by luke280
That's right. The resistor, when heat shrink wrapped, dissapears.
serious comment or sarcastic? These wires are pretty tiny, and ive cut all the way up to about 1/4" away from the LED holder
Not sure what type, or where you have purchased your LED lights. I would assume that you would have gotten to the resistor by now if it did. But they are pretty small, so they kinda "dissappear". You could always test the LED for resistance with a volt meter.
... what kind of resistance should i be seeing?
Checked it out, you will need a 470 Ohm, 1/4 watt resistor for each LED.
yah they are off a strand of LED christmas lights, all wired in series, so i doubt that there would be enough power to push them all if they all had resistors. Ill take a pic this after noon to show you what im looking at. So what kind of resistance should i be seeing?
Okay -- I hate to dredge this up again but, I'm ready to order a switch and I want to be CERTAIN that I get what I need here.
Here's what I want it to do and what I think I need:
I want to mount the capsule (magnetic reed switch) under the black plastic that is in the lid underside at the front (near the latch). In short, the capsule is out of sight and all wiring is kept beneath the plastic in the underside of the lid.
I'll then mount the magnet beneath the lip of the console - very near where the latch actually latches. If the magnet is strong enough, it should trigger the switch (will the magnet be strong enough through two layers of plastic?)
That said, I think I need a NC magnetic reed switch - correct? That would be one that, when exposed to a magnetic field, the wires within the capsule separate, correct? Pull it away from the magnet source and the wires touch thus completing the circuit yielding LIGHT.
The wiring will be like this:
From 'hot' wire on 12v rear seat adapter via 18 guage wire to a inline fuse holder (not sure on how big to guage the fuse)... from fuse holder to switch... through the switch... backside of switch's lead to all LEDs 'hot' wire.
From 'ground' wire on 12v rear seat adapter via 18 guage wire to all grounds on the LEDs.
Done... correct?
Please confirm that this will work out... thanks guys!!
-RP-
Done... correct?
-RP-
This link may help http://www.superbrightleds.com/led_info.htm
this is where I got the 120+ leds for the dash edge lighting.
From 'hot' wire on 12v rear seat adapter via 18 gauge wire to a inline fuse holder (not sure on how big to gauge the fuse)... from fuse holder to switch... through the switch... backside of switch's lead to all LEDs 'hot' wire.
Done... correct?
Done... correct?
If they don't have them built in, get the correct resistors to bias the LED and then calculate your current.
Thank you, sir!
They do have built in resistors so, I believe I'm good there. I'll back-calculate into the fuse size (I just feel more comfortable putting one in line -- safety if nothing else).
Other than that, I'm golden?
Originally Posted by vtron
Looking more and more at this -- this should be cake as long as the magnet works through the plastic on both the lid and the console. Any chance in kicking the magnet strength up to ensure function?
I'm looking at a full list of Reed magnets from Cherry on digikey -- just not sure which one is the winner for this functionality.
Thanks guys!!
-RP-
