Travis at KCAutosound is da man!!!
Originally Posted by hmfic
Is this a good deal? Its a ca 670.
http://cgi.ebay.com/CODE-ALARM-CA-67...QQcmdZViewItem
Yea I think for an extra hundred bucks or so I would go with Travis's product just because of the customer service... Think about it, he knows these trucks inside and out and is willing to give advice on anything he can, it's worth it in my book.
Originally Posted by fx4jake31
all of you are installing these alarms yourselves?
Originally Posted by BestNTx
I have yet to buy one from travis... but he prewires the kit for your truck from what I understand so its almost a plug & play deal, except for tapping into some fuses.
You tap lots of wires, but no fuses...In fact, I didn't even remove the fuse panel cover (right kick panel) during the install. It's very easy with his instruction set, and his pre-wire was great except for one wire that he mistakenly clipped. The programming part is tougher, but he's almost perfected the instructions for that.
5 at the ignition - Heater, Ignition, 12v Constant, Starter, Horn
3 at the PATS bypass for the XK04 bypass module
2 behind the headlight switch for parking lights and dome light
8 in kick panel - lock, unlock, ground, brake, door trigger, plus 3 wires for the keypad
1 wire behind your center console for heated mirrors
1 wire for the tach signal at the fuel injector
I know that seems like alot but Travis preps the harnesses on the systems so that when you mount the brain in the location he recommends all you have to do is route his taped up harnesses to the locations then make the connections. He makes it so simple and his instructions come with pictures with most vehicles and he gives you wire colors, locations and what they will do with your test light. If you get jammed up you can give him a call and he'll take care of ya.
Originally Posted by DirtyDoggT
Sorry to correct you but just want to give you and others some info on his systems. The CA670 has a total of 20 connections.
Sounds like a stand up guy, with excellent business skills. I will be buying an alarm/remote start when I scrape up some cash.
My truck is having a terrible time starting. The battery is fine, the starter is fine...it kicks over at full power but the damn thing won't start. How will the remote start handle a false startup? I'm thinking it's just the fuel draining back into the tank, and giving me dry starts. Going to change the fuel filter and see the results.
==> Almost ready for another Pismo Trip??? You fix your 4x4 yet, I wanna go for a ride in your beast??
fx4jake31 all of you are installing these alarms yourselves?
Originally Posted by TeckBargins
Ive had a few issues with my 06 starting up. I wonder too. It seems like to be more so when I have the edge in use ( not a 0 level, I return to 0 and seems to work fine ). But it happens random times almost for no reason. Have gas, only 10k miles, never had a starting issue with my 04
Stupid Valentines day might be cutting into my install... damn gf
My problem is everyday, everytime. Something is def wrong, it's obvious it has something to do with the fuel and/or fuel lines. Fuel Filter is just the first check and hopefully the fix. Maybe you should try that too.
