Poll: Which Probs Has Your Truck Had?
Old Jan 14, 2009 | 07:13 AM
  #46
DaMoose81's Avatar
Originally Posted by bri687
Do you have a TSB number for the leaf springs? I think i might have this problem too.
Ill have to look it up. They said that the TSB told them to lube them, that worked for about a minute, then back to clunking. It made the noise everytime one of the back wheels werent together. Like if i went over a speed bump at a angle
I took them about a month to get them in, then about 5 days to actually install them, they said they had to remove my gas tank, exhaust, and shocks.
Old Jan 14, 2009 | 12:03 PM
  #47
truckncrew04's Avatar
2004 FX4 Supercrew 3.73 with 88,000 miles, Bought used with 67,000 miles
1) One plug broke
2) Not sure
3) No
4) Pass side rear
5) Ticks
6) 3rd brake light leak. New gears had to be installed 3 weeks after I bought
the truck but dealer covered it.
Old Jan 14, 2009 | 12:10 PM
  #48
2005 Screw, 4x2, 5.4, 3.55 LS with 80,000 plus miles.
1. No none broke at 65,500
2. No Rotors were good, but had bearing failure at 41,000
3. No
4. No
5. No
6. Throttle body replaced and reflash at 1600 miles.
7. Replaced brake pads at 11,000 due to excessive dust
Old Jan 14, 2009 | 05:52 PM
  #49
4.6 Punisher's Avatar
06 F150 made in November of 05 with only 19,300 miles.
1 Nope
2 Nope
3 Nope
4 Nope
5 Nope
6 Nope
My inferior 4.6 isn't effected by overly sophisticated cam phasers and weird spark plugs, lol.
Old Jan 14, 2009 | 08:14 PM
  #50
07HD's Avatar
1. No
2. No
3. No
4. No
5. No
6. Squeaky back window, electric window switches failing.
Old Jan 15, 2009 | 07:59 PM
  #51
bri687's Avatar
Thanks, once you find it I'll see if i can get i looked at.
Old Jan 16, 2009 | 02:57 AM
  #52
masterd's Avatar
2004 F150 5.4 with about 155k on it.
1)NO
2)YES
3)YES
4)YES (plastic guides broke one 3 windows)
5)YES
6)Rear end was rebuilt twice.....3rd rear end still has issues, not as bad as the other two though.
7)Clatter on start up.
Old Apr 28, 2009 | 07:17 PM
  #53
NFBill's Avatar
2003 FX4 Lariat.
1. No
2. No
3. Yes .. sorta - hard shifting, was told it's kinda how they work.. dunno
4. No
5. No
6. EATC problems, Transfer Case problem.. other than that... the truck rocks!
Old Apr 28, 2009 | 07:36 PM
  #54
wolverine08's Avatar
My 04 scab stx 4wd:
-Shake/Vibe - moderate
-Bed patch removed (recall item)
My 05 scab xlt 4wd:
-Shake/Vibe - severe
-Warped rotors
My 06 scab xlt 4wd:
-Rear window leak
Old Apr 28, 2009 | 07:42 PM
  #55
Carlsson3's Avatar
So far– driver and passenger front window regulator/switch failure. Dealer replaced under warranty. Also, on three occasions engine begins to idle rough–seems to lose power as if its down one cylinder. Trans seems to act up–the shudder?. Seems ECM related, but I ain't no mechanic. Mysteriously disappears after shutdown and upon next start up, it's as if it never happened. I have yet to address the dealer with this issue. Also, pretty bad vibration from brakes– easily felt through steering wheel, especially slowing from freeway speeds.
'07 with less than 25,000 on the meter.
Old Apr 28, 2009 | 07:55 PM
  #56
bone79's Avatar
3. transmission replaced at 16,000 miles.
5. somethings been ticking since 4000 miles, dealer says it's normal.
Old Apr 28, 2009 | 08:28 PM
  #57
Ymustuh8me's Avatar
2007 SCrew 28k miles
1 no
2 no
3 no
4 Just starting to go out
5 Noticed a ticking about a month ago
6 emblems fading/peeiling, with only 4000 miles so far no real issues yet
Old Apr 28, 2009 | 11:18 PM
  #58
rocky57's Avatar
2007 XL V6 22,000 miles
I have had none of the listed problems so far.
The only two problems I have had are a cracked valve stem and the cowl cover popped out on the drivers side piece on the end near the center of the truck.
Service station replaced valve stem for 5 bucks and the Dealer fixed the cowl cover under warranty...sort of, it lookes like it is trying to pop back out of place again.
From what I have read here on the forum, my two problems have happened to others with some regularity. Nothing terrible but I was lucky I had the tpms when the valve stem cracked, I might have been on the side of the road changing tires without it.
Old Apr 28, 2009 | 11:24 PM
  #59
No problems except a shot head gasket, but it wasn't really Ford's fault...
I've got a 2007 4.2l V6 5 speed manual regular cab long bed rear wheel drive 4x2.
Old Aug 16, 2009 | 06:49 PM
  #60
sagittarius1's Avatar
  1. no
  2. no
  3. no
  4. no
  5. no
  6. door lock actuators
  7. fan speed modual
  8. billet antenna rusted into antenna base
  9. power mirror stripped mechanism
  10. right rear wheel bearing
  11. DPFE modual
  12. environmental control ***** cracked
  13. upper & lower ball joints
154,000 miles, 1999 F150 XLT 4x4 xcab
