Poll: Which Probs Has Your Truck Had?
Old Dec 4, 2006 | 12:00 AM
SilverScab 5.5's Avatar
Originally Posted by xlint1
If my memory is correct, when our new body style came out for 04 they advertised like $6 million invested in the Research & Design of this truck. Remember the guy standing under the truck being held by one bed bolt? From all the "common" problems found all over this website, what did they research? Please list the year, model, mileage, and acknowledge if your truck has any of these known problems. 1. Spark plugs break 2. Brake rotor problems 3. Transmission shudder 4. Elec. window motor failure 5. Cam phasers ticking 6. And feel free to list any other problem your truck may have. Mine is a 04 xlt 5.4L 53K with plug breakage, trans shudder before I got my tuner, and I have 1 elec.motor that doesn't roll up, and the other is slowing down. Thanks
What you need to realize is that no matter how much research goes into a vehicle, some will still have problems. There is no perfect vehicle and there never will be. That being said I think these trucks are very solid and quite reliable. It seems worse here because everyone is posting problems and it seems like they all have problems. This is not the case, I assure you that a majority of them are trouble free. By the way:
2006 XLT 5.4 Supercab with 9000 miles.
No problems as of yet, knock on wood.
Old Dec 4, 2006 | 08:49 AM
Tbird69's Avatar
Hmmmm....Let's see.
1.Clutch pack replaced in rear diff.
2.PCM reflash to fix throttle lag.
3.Front pads, rotors, and calipers to fix a steering shimmy when braking.
4.Drivers side window switch assembly replaced.
These things came up in the last few months and need to get looked at before warranty runs out (ends in January).
5.Clunk from driveline when turning a corner (feels like one rear wheel dropped into a hole).
6.Clunk from right front wheel when turning.
7.NASTY grinding noise from drivers window when moving up or down (probably regulator).
Outside of all this it's been a perfect truck! I'm dreading no longer having warranty!
Old Dec 4, 2006 | 09:19 AM
1. No
2. No
3. No
4. No
5. No
6. Throttle body replaced and computer reflashed at 1600 miles
Replaced front brake pads because of dust at 11,000, replaced rear because of wear at 37,000.
Almost 38,000 miles to date.
Old Dec 4, 2006 | 10:34 AM
cndcowboy's Avatar
05, 4x4 Screw Lariat, 75k km's (47 k miles)
1. I won't be changing them b/c my lease ends in one year
2. No
3. No
4. Maybe, my drivers window sometimes won't come up when it is all the way down. It will take 10-15 pushes of the switch before it comes up.
5. Yes, fixed by dealer
6. The parking brake would stick due to a crimped cable when it was new.
7. Almost 2 years old and I am on my third battery. My third one is a non-motorcraft battery, I will see if it can last longer then 11 months.
Old Dec 4, 2006 | 11:51 AM
AirborneRacer's Avatar
1 1/2 years, 3+ thousand miles and no problems yet
Old Dec 4, 2006 | 11:59 AM
worland's Avatar
'05 FX4 SCrew 5.4L
A. Head Liner Rattle (TSB)
B. Power Rear Window Rattle (TSB)
C. 6-CD MP3 Head Unit "CD ERROR" & Spitting CD's (TSB)
No Other Problems.
Old Dec 4, 2006 | 12:17 PM
hwyman's Avatar
2006 STX Scab 4x4 4.6L built @ Norfolk.
I have not experienced any of the mentioned problems, only a bas radio speaker in the driver's door. But then again, I've only put 5k on it so far!
Old Dec 4, 2006 | 12:39 PM
Racing2Fast's Avatar
2004 Screw 4.6 V8
3.55 Gears/ 2wd
Met. Silver
60,000 Miles
No Drive Train Problems
NOTransmission Trouble
NO Rear-End Trouble
Paint On Driver Door started peeling and you could take your finger and rub it off..... just in one spot....Almost like that one area had oily residue or palm print or something when it was painted..DEALER.. repainted with no trouble had truck back in 2 days and dealer paid for rental (chevy 1500) Was Damn glad to getback into my FORD!
GREAT TRUCK!! Wish She Had More HP... But Plenty For What I Need!
Old Dec 4, 2006 | 01:34 PM
RjA150's Avatar
I have 2 '04+ F150's. One is my '05 XL Reg Cab with 4.2 automatic that has about 46K on the odo right now and it has been flawless. The other is my wifes '06 STX Limited Edition SCab flair side with 4.6 auto with I think around 7k on the odo and so far it too has been flawless with the exception that it does have a little of the bed shake but its not bad enough to even worry about.
I dont feel that these trucks have had any more problems than any other vehicle does after a total redesign, there are going to be bugs that need to be worked out. Thats why I specifically didnt buy a '04 and waited on a '05. I would never buy a first run year of a new design. And the reason that these boards seem to be over run with problems is because the owners that dont have problems dont have a reason to post anything. I love both our F-150's and wouldnt want any other brand
Old Dec 4, 2006 | 01:50 PM
Buzzz's Avatar
1-5 NO
6. Cluctch pack in rear end twice in 55K freeway miles. Rattling rear power window. Steering wheel nibble. Transmission clunk.
Old Dec 4, 2006 | 05:11 PM
kalebarellano's Avatar
Are all of these somewhat easy fixes? How hard or expensive is it to fix the cam problem, and what about the rear diff problem? What exactly is the tranny problem? Are most of these problems associated with the 04's, than the newwer years?
Old Dec 4, 2006 | 06:24 PM
fordabbits's Avatar
All of my problems just so happened to have happened atfter my ext. warranty ran out. how bout that!
TPS Sensor replaced
window regulator (cable took a dump)
still something wrong w/abs that these idiots cant figure out.
Other than that, no powertrain probs.
Old Dec 5, 2006 | 11:43 PM
KJs04Fx4's Avatar
kalebarellano
I know prices vary from state to state, but the dealership quoted me $1366 to replace the cam phasers. Said they could do it in one day.
Old Dec 6, 2006 | 01:44 AM
xlint1's Avatar
Wow. There is alot of diversity in this thread. Most everyone on here loves their truck, but it does appear the guys with no problems generally have low mileage. And yes it is odd that problems occur just after your warranty is up. I understand first model year vehicles have bugs to be worked out, but what about the guys with 05 & 06s having the SAME issues as me with the 04? Do you think they solved the sparkplug problem on the 07? Probably not. I just don't like having to pay alot of $$$ (usually over $1K) for a tune up if it goes bad. And another $1300 if the cam phasers go too. Anyone see what the resale value is lately? It's not good, and going to get worse once word is out.
Old Dec 6, 2006 | 12:07 PM
ChrisAdams's Avatar
Actually the guys with the problems are the ones with the 5.4.
The 4.6 is pretty much bug free.
Even the vibration doesn't happen to the 4.6. Only 'bugs' they have involve the brakes and even that is fairly rare.
I see a few posts about problems coming up right after warranty ends. That is out of thousands of members.
Extrapolating a little are we?
Chris
