Any 2005 owners cure the steering wheel nibble?
Originally Posted by MeanGene
Kind of funny to see everyone copying the 2004+ F150, even Toyota claims a full boxed frame, but after reading about frames in general I found this from the Toyota web site.
"The Tundra's advanced TripleTech frame uses wide, full-boxed frame rails for the front portion, reinforced C-channel under the cab and an open C-channel underneath the bed to maximize strength, ride quality and durability.
Compared to the previous Tundra, the new model features more reinforced areas, increased high strength steel, increased steel gauge, and higher-rigidity suspension mounts. The engineering pays dividends in both work capability and ride-and-handling."
It's not a fully boxed frame from end to end like the F-150, but maybe they have a good reason for that.
I'd also like to know more about why Ford claims a fully boxed frame is superior. I mean I understand the idea that a boxed frame is stronger. But if that's the case, then why dothe new 2008 Super Dutys have a c-channel frame??? If fully boxed is so much better/stronger, then why not give a truly heavy duty truck a heavy duty (fully boxed) frame?
I think there's got to be more to it than "fully boxed is superior"...
The new Super Duty has a fully boxed front frame. The frame is thicker, with additional gussets providing even more strength and durability in high-stress areas. This is the thickest gauge steel in any pickup. So although only the front frame is fully boxed, the frame is the thickest and the strongest.
This is getting off topic. If it was a frame issue it should be acting up right from the start, no? My 04 5.4L Scab steering wheel shakes just started to develop around 57K mi. I thought it may have to do with the 2.5" leveling kit I installed a while back causing ball joint issues. So I removed the kit, realigned the front end, and had all 4 wheels rebalanced. The shaky wheel happens with stock 17's with Hankooks and my 20's with Goodyears. I've never had an issue until recently. Which leads me to believe there is a wear problem with some particular part. I will be looking into this further and post my results. How many people with the nibble have leveling kits installed and at what mileage did it start to shake?
My 04 STX also has the nibble. I've had my tires balanced 3 times in the past 6 months... no change. One shop told me to have all my rotors turned. But it doesn't shake when I hit the brakes like warped rotors do. I crawled under the truck this morning and my driveshaft has a bit of play in it. I'm hoping my nibble is just a U-Joint. Anybody else's driveshaft wiggle at all?
FYI, My truck does have an AS 2.5" Level Kit.
Originally Posted by little Buro
I did not have the nibble until I did the 2.5" leveling kit install. I thought during the installation I must have nocked a weight loose or something. I just had new tires and wheels installed today and it is much worse at 55~70mph. I will try and get them rebalanced and poss. road force balanced tomorrow. I still have the kit installed.
I've heard this story so many times it makes me sick. I have the same problem and have changed and balanced everything without a change. Let us know if you find the magic solution.
I think some people have tires out of balance that think they might have the nibble problem. The true nibble problem does not go away with tire balance, new wheels, alignment, etc.
Originally Posted by Buzzz
The only people that I have heard about that cured their true 'nibble' problem have had the steering rack and other components replaced. This is next to impossible talk the dealer into doing. It stinks.
My thoughts exactly. I call mine a nibble, but it may be more of a shimmy. The steering wheel giggles back and forth a good 3/8 to 1/2 inch or so at its worst. Its not just a vibration.
In addition, I don't think Ford Can fix it. The proof being that they are still making them with the problem. Obviously they are incapable of a resolution if they can't make them right to begin with and have acknowledged that the problem exists for years.
I wasn't aware that the new trucks still have this problem. That sucks even worse.
