Any 2005 owners cure the steering wheel nibble?
Originally Posted by Buzzz
Well I checked and the center hole on the rim fits very very snug on the hub. Crap.
I have a co-worker with a 2006 XLT. We are going to swap wheels/tires this weekend and see what happens.
This is a very time consuming method but a positive way to isolate the problem. Document each wheel and location as you will need to show it to your dealer.
Swap all wheels and drive both vehicles. If yours is fine at this time then replace one of your original wheels at a time to the front of your truck and drive after each installation. If it is ok after each wheel is placed on the front move it to the back. Repeat until you find a bad one or bad ones. Mark it / them and leave it / them on the front. Now go after the place of purchase. It could be a tire or a wheel or both. Good luck. Mine was found to be 2 defective tires but I suspect that the wheels could be a contributing factor.
