Front Brake Pad Change (Brake Dust ...)
OK ... I've about had it with BRAKE DUST!! That, along with my dismal 13.5 MPG avg, has almost pushed my to trade this truck and say "good-bye" to Ford!
BUT, before I go to that extreme, I think I'm going to try out Akebono’s advanced ProACT™ Ceramic Disc Pads on my front brakes.
My question .... for those that have changed their pads for this reason, did you just do a "pad slap" (just changed the pads & that's it) or did you have to resurface the rotors, etc.??
I have about 11,500 miles on my FX4 ... I don't have issues with the rotors, just the outrageous amounts of brake dust up front.
I think its just certain pads on certain f150's. I had 2 different STX's (both 04's) and the brake dust was horrible. But the one I have now has no brake dust problems at all. NONE! So maybe take the truck into the dealership and have them put the pads from an 07 on your truck...if they are willing. Just a suggestion
I got tired of the brake dust, dirty after every trip. I put on KleenWheels. No more brake dust. Period. My rims stay clean as long as the truck does. No difference in brake temps. Cost less than pads by quite a bit.
Only fit stock type rims.
I also don't miss seeing my rotors with rust colored calipers. The flat black finish just makes my rims show better.
Chris
Chris
Originally Posted by JurassicBob
I did a quick search before I posted but couldn't find anything.
There is a SB on brakes, but it has nothing to do with dust.
I just had mine done, and by the time I got home, the brake dust was everwhere.
I had removed my KleenWheels as I didn't want some mechanic bending them up. They are very delicate off the truck.
If your truck is covered by the SB, do get it done. My brakes are better than ever with the new calipers, pads, rotors, wheel bearings.
But the brake dust is exactly the same.
Chris
Chris
Chris
Chris
