Push Button Install Help
Old Oct 11, 2006 | 11:59 PM
etrevino103186's Avatar
Originally Posted by MPSchenck
...and uphill both ways. Right?
haha!
anyone familiar with this wiring?
Old Oct 12, 2006 | 12:01 AM
-TXF150-'s Avatar
Originally Posted by etrevino103186
haha!
Post the instructions, and ill try to help you out..
Old Oct 12, 2006 | 12:30 AM
Josiah's Avatar
bhf150 did an amazing install of one. His e-fan indicator lights are right next to it, the pushbutton replaced the cig lighter. I'm sure he'll chime in after the beating you guys gave him for blowing his engine
Old Oct 12, 2006 | 12:39 AM
ieee_raider's Avatar
Originally Posted by -TXF150-
Ok now I see you do understand how they work.
Typically you need to have a transmitter within a certain range in order to be able to turn a car on and off with a push start system, like on a BMW or newer cadillac or corvette..
Or an '07 Camry, such as my wife's... ;-)
I did this in my '00 Focus. I used a series of hidden switches and pushbuttons to trick the system.
I had one switch to emulate the "on" position and a pushbutton to emulate the "start" position. Both were hidden under the dash, but within reach.
I also had to bypass the Securilock system.
Old Oct 12, 2006 | 03:30 AM
azmidget91's Avatar
you need to figure a way to use the pats system with out having to put the key in, not sure how but that would probably be the best way to do it
Old Oct 12, 2006 | 05:58 AM
charlie101's Avatar
http://www.bypasskit.com/product.asp...KU-F1&catid=16
Old Oct 12, 2006 | 08:50 AM
gatortech's Avatar
The only way to bypass the PATs system is to use one of the many bypass modules. Like used on remote start systems. Commonly when doing push start systems you'll have to put the key in and turn it to the run POS. then push the button. This way your still using the PATs system and joe cant just jump in press the button and go. You'll need a relay, push button, and wiring.
Old Oct 12, 2006 | 09:14 AM
ok well my roommates scanner isn't working but i am heading home today so i'll scan it and post it on here. thanks for the help guys.
Old Oct 12, 2006 | 10:16 AM
I bypassed the PATS/Securilock system using a jumper wire in the wiring harness. Wasn't that complicated. No module required.
The initial reason i installed a PB start was that my key was stuck in the ignition. It took 2 weeks to get a new ignition assembly in, so in the meantime I used the PB start.
Old Oct 12, 2006 | 05:31 PM
Josiah's Avatar
Are you using the pushbutton by ignited?
Old Oct 12, 2006 | 05:43 PM
Y2KWHT150's Avatar
If it's that easy, anyone can start by bypassing (using jumper) to drive off...dang
Old Oct 12, 2006 | 05:51 PM
Shoulda called me, i have a scanner at my apt... Anyways hope you have a good weekend. ill see you sometime next week. Oh if you didnt already see in the screw forum, i discovered today that recently someone has tried to break into my truck.... https://www.f150online.com/forums/sh...d.php?t=256925
-Patrick
Old Oct 12, 2006 | 06:31 PM
azmidget91's Avatar
thats how it has always been, except you probably know it as "hotwire"
Old Oct 12, 2006 | 07:34 PM
-Patrick
that sucks Pat, thats what you get when you live in ghetto *** Waco. My roommate and I were messin with it, I'll give you a call Sunday when I get back maybe you can help me out. Is my siren loud?
I am still going to have to turn the key but I push the button and it says engine start.
