Push Button Install Help
Old Oct 11, 2006 | 08:03 PM
etrevino103186's Avatar
Has anyone successfuly installed one of them? I am going to try to scan the instructions but they appear to be written by someone who does not speak very much english...
Old Oct 11, 2006 | 08:42 PM
gatortech's Avatar
push button start?
Old Oct 11, 2006 | 09:01 PM
you push the button and it starts the truck.
Old Oct 11, 2006 | 09:21 PM
GotBeer's Avatar
I have done a few of those. Not too hard. Connect one end to the battery and the other to the small terminal on the soleniod of the starter. Make sure you use heavy gauge wire. The hardest part will be making it look nice inside.
Old Oct 11, 2006 | 09:38 PM
02SuperCrew4X's Avatar
Yeah.. thats cool and all. But you should wire it so that you dont have to have the key in the ignition. This way, you can get in, push the button and drive the car/truck. I wonder if there's a way to do that...
Old Oct 11, 2006 | 10:00 PM
BalogUK's Avatar
but that way, someone could have a nice 05 truck for the cost of a new driver side window.
Old Oct 11, 2006 | 10:08 PM
patshea098's Avatar
my thought exactly.
add a keypad with a code hahaha
Old Oct 11, 2006 | 10:11 PM
ONE04FX4's Avatar
Talking
how about using the wires that an alarm would use. even go on the side of the alarm so it will also be able to work. but doing this will bypass whatever system the truck turns off during start. could be done. this way the key switch will have to be on and the alarm will still stop it from working.
Old Oct 11, 2006 | 10:18 PM
Tbird69's Avatar
According to my grandfather there once was a time when people weren't afraid to work for what they want. You know get into the vehicle, insert the key, and actually turn it to start said vehicle. I'm not sure how much of what he says I should really believe, according to him he used to walk 5 miles to school barefoot through the snow.....
Old Oct 11, 2006 | 10:22 PM
supachargd2k5's Avatar
lol
Old Oct 11, 2006 | 10:37 PM
i am trying to bring those days back by adding an extra step, put the key in, turn and pushing the button
the wiring says to tap the positive parking light, connect the ground, connect the ignition wire and connect the starter wire i know everything else is right but the ignition wire i am not sure where to cut it or hook it up i tried almost every combo i could but it wouldn't work...
Old Oct 11, 2006 | 10:46 PM
-TXF150-'s Avatar
Originally Posted by patshea098
my thought exactly.
You two obviously have no idea how push button starters work..
Old Oct 11, 2006 | 11:30 PM
BalogUK's Avatar
youre right i have no idea- lets not be an *** about it- the comment before mine was about not having to use a key in the ignition.. if you're going with a bmw style with the transceiver thats all well and good-
btw- Bushwacker
J
Old Oct 11, 2006 | 11:36 PM
-TXF150-'s Avatar
Ok now I see you do understand how they work.
Typically you need to have a transmitter within a certain range in order to be able to turn a car on and off with a push start system, like on a BMW or newer cadillac or corvette..
Old Oct 11, 2006 | 11:53 PM
MPSchenck's Avatar
...and uphill both ways. Right?
