Edge AMPG Question
Old Oct 12, 2006 | 01:31 PM
TeckBargins's Avatar
Edge AMPG Question
Is anyone elses edge reporting upwards of 24+ average miles per gallon??
If I reset it, it works perfect for a while then it just builds up until its passed 20+ average miles per gallon.
Old Oct 12, 2006 | 01:47 PM
whitecrystal1's Avatar
I wish that would be the case and I was really getting it.
No, mine seems to get within less than a mile difference from the one on the dash. Probably more like a half a mile diff. It does track a little high at first after I reset it but it comes down to the same after maybe a 100 miles or so. I have never updated mine either. I should and will sometime because I get the shudder in the rear in level 3. A problem I have somtimes with mine is the display twice has had a blank screen and I also have seen the display on mine freeze the readings and I have to push the enter button to get the readings to read current again. I don't think that is temp related but I'm not sure why it does that either.
Old Oct 12, 2006 | 01:48 PM
05supercrew's Avatar
Did you reset it while the truck was moving? I did that the other day and was getting crazy readings. You have to be at a complete stop.
Old Oct 12, 2006 | 01:55 PM
kd4crs's Avatar
Have you updated the Evo with the latest firmware and software? EDGE made several tweaks to the MPG feature to increase the accuracy in the later versions of software.
Old Oct 12, 2006 | 06:53 PM
AirborneRacer's Avatar
When I was displaying my AMPG it was always between 12-14.5 depending on my driving which is mainly city with a few miles of freeway I can set on CC sometimes.
Old Oct 12, 2006 | 09:04 PM
Trooks2001's Avatar
You need to update
Old Oct 12, 2006 | 10:03 PM
yea I figured it was just an update needed but just wanted to see if others had the problem
thanks
