LED Instrument Illumination Upgrade
Old Sep 16, 2006 | 11:04 PM
dlewis1340's Avatar
I swapped out all 5 instrument lights with LED "super white" lights. I was trying for a look similar to the look "blue/white that the navigator and the new tahoe.
Don't even bother. I immedaitely removed all the LED's and went back to the incandescant bulbs. Dash was actually DIMMER with the LED's.
Waste of 8 bucks on LEDs and 30 minutes of time. Oh well.
Old Sep 16, 2006 | 11:12 PM
nuclearthreat54's Avatar
Do what I did
Two blue LEDs aimed at the cluster. You can probly get 3 if you want.
Old Sep 17, 2006 | 10:48 AM
Impact9's Avatar
I've heard different on the LED from SuperbrightLEDs.com. My wifes 01 Escape odometer light when out so I researched the LED replacements. Over on Escapecentral the members there was saying the SuperbrightLED.com LED's are very bright and all recommending changing out all the bulbs for LED's to keep the cluster evenly lit. I got mine in yesterday and I'll be putting them in the Escape today and I'll post my results.
Old Sep 17, 2006 | 11:38 AM
scorpio333's Avatar
Those reflections would drive me insane. Then there's the shadows Not a bad idea, just needs softened/diffused IMO.
Old Sep 17, 2006 | 03:21 PM
HIDPLANET's Avatar
When done right, it can make for a nice unique cluster without brightness issues:
http://smg.photobucket.com/albums/v5...gAnch=imgAnch7
Old Sep 17, 2006 | 04:09 PM
xplorgee's Avatar
Id like to see a really nice blue LED setup. Im pretty sure its possible but the right combo of leds will be needed I guess. I would do it but im too lazy. Ive had a Ford for all my cars and would like to see something different than the green.
Old Sep 17, 2006 | 04:10 PM
dlewis1340's Avatar
My brand was "superbright led.com"
I think the multi LED bulb clusters may be brighter but the ones needed for the 150 (1.5's) are only single led
Old Sep 17, 2006 | 05:36 PM
brypink2's Avatar
HIDPLANET...help me do that cluster!!!! That's pretty fricken cool!!! What do I need...parts? And, how about some directions/install?
Old Sep 17, 2006 | 05:43 PM
tardman91's Avatar
I think that's a VW cluster. I don't think that is in an F150.
Old Sep 17, 2006 | 05:47 PM
brypink2's Avatar
After a second look, I kinda realized it wasn't a F150. I got too excited too fast.
I'm dying for my cluster to look similar to that though!!! I hate the green lighting.
Old Sep 17, 2006 | 07:04 PM
scorpio333's Avatar
X2! I'd like to get the green looking like the blue of the high beam indicator.
dlewis1340, when you put the LEDs in, did the light "spread" to cover all of the gauge? Or did it light part of it enough but not consistently throughout? I'm not looking to get super bright, I usually keep my dash lights set a little over 1/3 brightness, mostly due to the dislike of the green, but I don't need anything brighter for my tastes.
Old Sep 17, 2006 | 09:44 PM
HIDPLANET's Avatar
That was a completly custom installation done by someone on my forum.
The point was, when done right, it can turn out great, but just like with tail lights etc, using drop in replacements wont get you anywhere.
This guy did this by using a lot of custom circuits and leds to follow the needles and such. But good LEDs were also used to illuminate all the gauge cluster lights.
Using a superflux LED would probably provide far enough light to illuminate the back of the cluster if installed properly with a circuit and triggers.
Old Sep 17, 2006 | 10:05 PM
Impact9's Avatar
This is for those interested in changing the stock green to blue.
If the insturment cluster is anything like the used on the Ford Escape then there is a thin green film behind the white face plate that makes the green color. Plus a green cover over the individual bulbs. You have to remove the needles and then gentley remove the white face which is glued down. Then sand away the thin green film. Replace the lights with your new bulbs and enjoy.
Probably not worth trying unless your prepared to buy a new cluster.
Old Sep 17, 2006 | 10:08 PM
Why not just get the cluster from a mark LT or just get a new cluster face from a AM company that does that
Old Sep 17, 2006 | 10:34 PM
brypink2's Avatar
Know of one?
