LED Instrument Illumination Upgrade
Old Sep 18, 2006 | 02:25 AM
  #31
brypink2's Avatar
Originally Posted by Josiah
And that hi-beam indicator blue is a beautiful color. I love the Lariat gauges but what lights are you trying to change out? The bulbs in my window switches go out all the time, need replacing. You're not talking about the actual green that lights up the notches on the gauges, speedo, etc. are you.
Anything green in the cluster, numbers, messege center, gauges, etc.
The color of the high beam indicator would be cool.
EDIT: Is a new cluster (FX4) really $1000 new?
Old Sep 18, 2006 | 05:50 AM
  #32
scorpio333's Avatar
Cheapest I seen em new was $1249, you got a bargain there for $1000!
I'm also looking for changing anything green in the cluster, I can live with the green message center.
Old Sep 18, 2006 | 10:05 AM
  #33
styxnpicks's Avatar
fyi the window switches, headlight **** and hvac controls are surface mount leds
Old Sep 18, 2006 | 11:55 AM
  #34
nuclearthreat54's Avatar
That must be for a new message center also.....but jeeze why so much.
Old Sep 18, 2006 | 06:29 PM
  #35
dlewis1340's Avatar
To answer the question - The LED's light spread evenly across all the instruments. There were no "hot spots" of light but the light was very very dim compared tot he stock bulbs..
So the overall light was much less and the green color was still there regardless of whether I used "super white" or "UV-Blacklight" LED
The UV lights were less than half the brightness of the super whites.
Bottom lines is that the green color still dominates regardless of what bulb I tried. Guess unless you want to remove that layer you are stuck with green.
The surface mount LED's (ac/radio and other controls) can be swapped but I wonder if there is that green layer on them as well?
Old Sep 18, 2006 | 07:39 PM
  #36
etrevino103186's Avatar
how is it that new stangs have adjustable colors?
Old Sep 18, 2006 | 07:57 PM
  #37
gatkins94's Avatar
I was thinking the same thing. We just bought a new Mustang, and almost everything about the dash is very similar to my truck, including the info buttons, and the display window. I wonder how hard it would be to swap out the items that would be needed to do the color thing.....by the way, I like it RED, and the wife always changes it back to blue???
Old Sep 18, 2006 | 08:01 PM
  #38
BluesCrew_FX4's Avatar
The Mustang has a clear faceplate and uses 3 colored LED with varable intensity, combined with the use of fiber optics. Wouldn't be a easy mod.
Old Sep 18, 2006 | 10:07 PM
  #39
styxnpicks's Avatar
there is no green layer I DO know that using a blue keychain led
Old Sep 18, 2006 | 10:08 PM
  #40
styxnpicks's Avatar
probably tri-color leds. alows for any color including white
Old Sep 19, 2006 | 02:04 AM
  #41
Impact9's Avatar
I was on Moss Motors (f150store.com) and seen Gauge Face kits running like $250. My understanding is that they will change the color of the backlighting. Here's a link:
http://www.f150store.com/Browse/Plat...omponentID=149
Old Sep 19, 2006 | 04:32 AM
  #42
xplorgee's Avatar
I dont know if i like the looks of the stainless steel face. Its to edgy for me. I like the way my friends VW dash looks. Nice if ford could do that. I guess its a german thing.
Old Sep 19, 2006 | 11:28 AM
  #43
Impact9's Avatar
I fixed the link. There's also a billet style and colored faces. I sort of like the blue models but it's just a bit too baby blue to push me into buying it.
Old Sep 19, 2006 | 06:02 PM
  #44
dlewis1340's Avatar
Wrong !! The color of the backlight is NOT controlled by the bulbs. Itried white, UV blacklight and red led's and the instruments were always green. There must be a green coating somewhere in the instrument cluster.
Old Sep 19, 2006 | 08:29 PM
  #45
styxnpicks's Avatar
I'm not talking about the instrument cluster. I was taling about the hvac controls and various switches
