4x4 spindles...
Old May 30, 2006 | 01:49 AM
04procompLARIAT's Avatar
4x4 spindles...
can you put 4x4 spindles (or knuckles) on a 2wd truck?
Old May 30, 2006 | 02:00 AM
NorthCoast's Avatar
Thats a great question. I would expect that the wheel bearings/hubs are completely different for the CV axles. From pics I've seen its a seperate bearing assembly that bolts to the knuckle itself, much like a FWD car. I would wager that it doesnt jive with a 4x2 knuckle. I'm sure there are those that know for sure, and maybe someone has pics? Why do you ask, are the 4x4 knuckles greater in length than the 4x2? I know the shock assembly is longer by about 5/8 of an inch.
Old May 30, 2006 | 02:05 AM
Yea the 4x4 knuckles are longer than the 2x4 ones. I put the 4x4 coilovers on my truck so I got a higher lift out of it and now my upper balljoint is pretty much maxed out. I was thinking if i put these on my truck it would even everything out, and maybe let me go higher for some 37's.
Old May 30, 2006 | 02:11 AM
NorthCoast's Avatar
how much longer are they?
Old May 30, 2006 | 02:48 AM
maybe an inch i believe.
Old May 30, 2006 | 03:19 AM
Josiah's Avatar
The halfshafts go through the knuckles.
Old May 30, 2006 | 03:31 AM
I know. My brother has a 2wd titan with a 4wd kit on it. So therefor he has the 4wd knuckles on it. So I was thinking it would work on my truck. I do believe the hub assembly on the ford trucks have the same mounting hole position on the knuckle for the 4wd and 2wd. I am gonna take my wheel off tomarrow and look to see how they are on my truck. I seen the trucks episode where they have the 4wd knuckle for the F150, so ill compare.
Old May 30, 2006 | 09:45 AM
Silver05's Avatar
With the way you have the front super raised up I thought you had a 4wd truck. Since you've gone off road in your truck were you able to go thru alot?
Old May 30, 2006 | 04:31 PM
I go just about everywhere 4wd's go in the desert. All I have to do is keep the speed up so I dont get stuck.
Old May 30, 2006 | 08:00 PM
NorthCoast's Avatar
Be interesting if the 4x4 spindles DID work on a 4x2 as that would mean most of the 4x4 lift kits should be adaptable. But at the same time I would say they arent since there are both kinds of kits available. So a 4x4 has a slightly longer coilover and longer knuckles, is that the only difference? I thought I once read on here that the subframe sat a tad lower as well.
Old May 31, 2006 | 03:39 AM
cesardajr's Avatar
Talking
Interesting....
