JLT intake is finally released
Originally Posted by thais0n
Also, wouldn't that thing just be sucking in hot air? I can definitely see how it will pull more air, but it will be alot less dense hot air.
Ok i talked to JLT. That is with NO performance tuning, just adjusting for the maf placement with the new intake.
I'm trying to get them to send me some charts, conditions etc.
Fatherford, didn't you make a post saying you sold your truck?
JLT Site Info
I don't know still seems like it is all the programmer
https://www32.ssldomain.com/jlttruec...year=2004-2006
New JLT Ram Air Intake for the 04-06 5.4 F-150!
At JLT we decided to break from the norm with this all new Ram Air Intake for the new 5.4 F-150 trucks. Until now all cold air intakes were the same old boring 90 degree bend and a filter behind the driver’s side headlight. Not anymore!
With this totally new intake from JLT you get something different and something better. We shorted the distance the air needs to travel, got together with SCT for a tune and came up with huge power as a result.
You get a high quality 89mm billet aluminum Mass Air Flow housing, that has been C&C milled to hold your stock MAF sensor, a large JLT heat shied designed to block the radiant heat from the engine at low speed and the HUGE, in your face, S&B life time re-usable filter, shall we say, Corvette LT1 style in front of the throttle body.
We joined forces with the best at SCT to make the perfect power package. The SCT X-2 tuner comes pre-loaded with JLT specific tunes in 87, 91 and 93 octane ratings. With the SCT X-2 tuner you can make 100’s of adjustments for gear and tire changes, shift point changes, check trouble & clear codes and on and on. Read more about the X-2 on the SCT page.
At JLT we tested this kit over and over and showed repeated results in the 25-30+ HP gain and an amazing 40-50+ TQ gain at the rear wheels!!!! Check out the gains at only 3100 RPM, 35+HP and 55+TQ!! This is power you can feel, take a look.
This comes with a complete JLT RAI kit, the SCT tuner loaded with 3 performance tunes) We have seen gains of 30-40+ HP with the 93 octane tune.
Product Info: The XCalibrator 2 allows 2 analog inputs when data logging (such as Wideband O2s). Also, because everyone should know what those Check engine lights mean, the XCalibrator 2 allows you to read and understand these codes the minute they appear so you can get back to enjoying your favorite vehicle.
-TUNE your own vehicleFOR MAXIMUM BOLT-ONPERFORMANCE!
-MONITOR & Adjustyour vehicles DATA &PERFORMANCE!
-Datalog Hundreds ofyour vehicles EECparameters
-The XCalibrator 2 arrivesPre-Loaded with three SCT Calibrations
Complete User Adjustability: -Fuel Adjustment - Wide Open Throttle: 6% Leaner to 14% Richer
-Spark Adjustment - Global Spark: -5 to +5 degrees
RPM Adjustment Spark: 0 - 2000RPM: -14 to +4 degrees
2000 - 4000RPM: -8 to +4 degrees
4000 - 8000RPM: -8 to +4 degrees
Axle Ratio Selection: 2.73 to 5.14 Ratios
MAF Selection: 80mm to 90mm Lightning SCT Big Air BA-2400 & BA-2800 MAF Meters
Tire Size Selection: 205/65/15 to 315/35/19
Fuel Injector Selection: 19lb to 60lb Fuel Injectors
Other Selections: Idle RPM: -300 to +300RPM Cooling Fan: On / Off TempTraction Control: On / Off Two Step: On / Off & RPM
Shift Adjustment: Automatic Transmission Shift Schedule:WOT 1st - 2nd: -3 to +7mph WOT 2nd - 3rd: -4 to +8mph WOT 3rd - 4th: -5 to +10mph WOT 4th - 5th: -5 to +10mph
Some of the options available: ·Raise Rev Limiter ·Raise Speed Limiter ·Shut off rear O2 sensor (for off-road mid pipes) ·Shut off EGR ·Fix Speedo after gear change ·2 step rev limiter (5 speeds 99+ cars) ·firm up shifts (automatics) ·turn off traction control permanently
Price: $555.00
Shipping: $20.00
Price: $555.00
Shipping: $20.00
No programmer will give this kind of power alone.
The JLT adds a ton more are with it's huge filter and larger MAF housing. This is a double edged sword as the MAF in these new truck (just like the Mustang GT) do not tell the computer what to do when you put the sensor in a larger housing, but adds great power.
So we need to tell the computer what to do with fuel, timing, MAF transfere and so on. This combo of more air and a tune makes huge power. It's not "just" the intake or "just" the tuner, it's both working together.
No, the Edge will not work, unless you go to a dyno and have a custom tune installed into your Edge porgrammer.
As far as heat... We knew this was coming, so we tested this as well. With the SCT X-2 you can data log tons of engine peramaters, including intake temps. We tested in city traffic and highway spped with great results. One thing we seem to forget is how much air flow there is under the hood of a truck. Just look down, you can see the ground.
At 30-35MPH in traffic we logged IAT's only 12-22 degrees above ambiant air temps. At 55+ IAT's were only 6-12 degrees above ambiant air temp. Hammer the throttle and the can get right near ambiaint temp.
I've been using it for 6 months or so with no issue and great performance.
Also, we ran a 15.5 @ 88 with a 4x4 screw lariat with only this JLT/SCT combo and a MAC cat back.
Jay
Jay
a similiar option currently available, you can get a Troyer custom tuned XCAL2 with the AF1 3.25" intake tube. This intake also requires fuel adjustments for the higher airflow.
Originally Posted by etrevino103186
so when are we gonna work on my truck?
Just let me know. I start my new job may 30th so we need to get this going sometime soon.
We gonna do UD pulleys and electric fans at the same time?
You going to want to go ahead and get the edge, or wait for the new sct that should be coming out?
They are bragging about the air temps being "only" 6 - 8 degrees above ambient. My shaker setup and my edge temp indicators showed a 1 deg difference at 60 mph. Now THAT is cold air induction! If i could get that elbow and filter into my shaker base.... HMMMM.....
If they had that setup with a svo style ram air, that would be cool!
The X-2 is only about 10 months old and it totally custom tunable. You can make adjustmenst for fuel, timing, gear and tire changes, shift points and firmness and a ton more.
Not to mention data logging, checking and clearing trouble codes and more.
I don't know of any "new" SCT tuners on the horison.
Jay
Jay
