JLT intake is finally released
Old May 3, 2006 | 10:24 PM
FATHERFORD's Avatar
I had been watching this for quite a while now. This was the intake I had planned on getting if I was still N/A.
It has been showing impressive gains of 30hp and 55ft/lbs at the wheels. The catch is you have to have a custom tune to run it.
This matched with other mods, I can see some very impressive n/a trucks in the future.
Old May 3, 2006 | 10:27 PM
ThumperMX113's Avatar
30 HP and 55 ft/lbs, but is that with the custom tune also? Im guessing so.
Old May 3, 2006 | 10:29 PM
FATHERFORD's Avatar
Yes it is. You also have to remember thats with a "generic" tune that comes with the intake. I'm sure with you got a true dyno tune, a little more power is in there.
What im wondering is how much a actual functioning cowl hood would help this setup.
Old May 3, 2006 | 10:30 PM
Now, is that over a Stock PCM tune and intake? . . or a tuned truck and stock intake? I thought the Edge gave gains like that by itself? . . or close to it?
Old May 3, 2006 | 10:40 PM
nuclearthreat54's Avatar
The thing is the edge might be more expensive. So with the intake and that tune being cheaper but gives the same or more power, it would be more disireable.
Old May 3, 2006 | 10:43 PM
The Edge can be had for around $320. I can't see this intake being sold for much cheaper than that plus, the addition of the custom tune would make it more expensive.
Old May 3, 2006 | 10:45 PM
FATHERFORD's Avatar
The intake sells for $199 at jusnesmodified
What really needs to happen is compare dyno charts. For everyone really starts assuming.
Old May 3, 2006 | 10:47 PM
I agree 100%
Old May 3, 2006 | 10:58 PM
I agree 100%
X's 2
Old May 3, 2006 | 11:12 PM
BADnBLUE's Avatar
What are the power gains on a 5.4 without the tune?
Old May 3, 2006 | 11:19 PM
FATHERFORD's Avatar
You can't run this intake without a tune.
Old May 3, 2006 | 11:23 PM
Old May 4, 2006 | 12:35 AM
cobraman302's Avatar
Im assuming that he means that you cannot run this intake without a tune because it will cause it to run lean, because of so much increased air flow.
Old May 4, 2006 | 01:13 AM
Tuff4rd's Avatar
Do you know if you can run it with a Edge tune?
Old May 4, 2006 | 01:52 AM
Josiah's Avatar
I'm wondering if most of the gains are from the tune, pointless if thats the case.
