PIE install question
Old Apr 3, 2006 | 11:59 PM
baja150's Avatar
Originally Posted by Doo2theSea
In looking at your picture you could either use a 3.5mm to RCA cable from the headphone jack on that unit to the PIE for audio or I also see a white connector for audio out on that unit (may be a sony proprietary size) to RCA for audio through your stock headunit
Hope that helps
Awesome! Learn something new here every day.
Old Apr 4, 2006 | 12:05 AM
Doo2theSea's Avatar
Can do the same with the headphone jack on your computer and plug into the back of your home stereo and play MP3's right from your hard drive
Old Apr 16, 2006 | 10:43 PM
Guigster's Avatar
For those of you who have had issues with sound as a result of a bad P.I.E., did you return them directly to P.I.E. for an exchange or did you return them to the on-line store in which you bought them?
Old May 11, 2006 | 02:53 PM
candrusiak's Avatar
The PIE looks like just what I need. The only thing I wonder about is getting power to the unit. Can any of you suggest the easiest way to do this? Please keep in mind that I have never made any changes to a vehicle electrically more difficult than changing bulbs and fuses.
Also, if any of you fellow Canadians have purchased these, where did you get them?
Old May 11, 2006 | 05:02 PM
jmpancoast's Avatar
P.I.E. is a pretty straight forward install. I used hot lead to my power supply port on the dash as a power source. I can help you with wiring diagrams if you need.
Old May 11, 2006 | 08:59 PM
ClemsonFX4's Avatar
I would also like to know about the power to the unit. Could some of you post any more information about this topic? Also does the pie unit charge the ipod?
