New Edge to update or not
Originally Posted by kanter
Sooooo many problems, Ill pass for now
Originally Posted by Silverfish
What are you customizing in the tune? That might help determine things....
Std. Shift-- 1to2 -1, 2to3 +5, 3to4 +10
Rev. Limiter--5400
Shift Points--5100,5100,4700
Timing-- +3
WOT fuel-- 1.6
That's it. Bill is working on it right now. I called at around 8:30 MST. Hopefully I'll hear back soon. If you see anything here, Silverfish, that could be the culprit, please let me know.
The only thing we did near the same was I adjusted the timing +1 and std shift point 1-2 to -2 and 3-4 to +10.
Let us know what Bill does!
jim
The std. shifting are the mph points (not rpm) at which the vehicle will want to shift under normal acceleration. Positive value will cause a later shift (on page 16 of manual). I like that it stays in 3rd longer under normal accel., shifts at around 40mph into OD. For city stop and go it feels the best with torque/power.
Originally Posted by Devin4X4
ugh..well i just filled up with 93 and downloaded the two programs from edge. I run the programs and it says the edge is not connected. Now what??
I havent recconected yet...the lightning software says its not connected
