Rear sway bar = night and day difference!
Old Feb 2, 2006 | 02:08 PM
  #76
CCRider's Avatar
Originally Posted by redelsinore
Well Bell Tech tells me thier Rear Sway bar will work on a 4X4.
CC can you shoot me a few more pictures?
Can you show me how the bar mounts to the axle tube, or diff housing?
I'm not convenced the 2WD bar will work on my 4X4, but I'll try it.
CC thanks for your help with this sway bar selection.
I posted the Belltech mounting photos in my gallery. Have a look!
Old Feb 2, 2006 | 05:45 PM
  #77
Riken's Avatar
where's ur gallery?
Old Feb 2, 2006 | 08:40 PM
  #78
redelsinore's Avatar
CC, thanks you've come through again.
Thanks man.
My concern with the 2WD bar on a 4X4 is the size of the block between the axle tube and the leaf spring.
It seems if these blocks are taller on a 4X4 the distance from the axle tube to the upper shock mount is greater.
If the distance from the axle tube to the upper shock mount is longer on a 4X4 than a 2WD, wouldn't the end links need to be longer to acount for the increased distance from the tube to the shock mount?
I'm going to buy the Bell Tech, and we'll see how it goes from there.
Thoughts? Anyone?
Thanx
Old Feb 2, 2006 | 08:42 PM
  #79
By the way CC what kind of rear shocks do you have?
Old Feb 2, 2006 | 10:39 PM
  #80
mlawdawg's Avatar
Here some links to some sway bars for lifted and not lifted 4x4s http://www.andysautosport.com/produc...sion/sway_bars
Old Feb 3, 2006 | 12:21 AM
  #81
CCRider's Avatar
Bilstein!!
Old Feb 3, 2006 | 09:57 AM
  #82
Your Bilsteins look different than mine.
Mine have flexable blue rubber boots on them.
Yours look like my fronts that have a ridgid skirt or sleeve instead of the rubber boot.
Just an observation.
I ordered the Bell Tech sway bar this AM.
Thanks for your help, I'll post an update when I get my Bell Tech.
Old Feb 3, 2006 | 10:16 AM
  #83
CCRider's Avatar
Must be my photos, mine are also the flexible blue rubber boots.
Old Feb 3, 2006 | 11:16 AM
  #84
Thrill Racing's Avatar
Ok, my cents (hell they arn't worth 2).
I am planing a swaybar installation with my Rancho installation. SOme have mentioned that Dodge and H2's are running rear sway bars. I can't comment about the H2 because they don't cater to anyone with a brain when it comes their website. I have however been in a powerwagen (freakin awesome).
The Dodge uses rear sway but has a front one that is electrinically disconnected. This giving it more agility. Why the rear isn't like this I don't know but its probabbly becauese the limiting factor to say a RTI index is the front so the sway bar in the back doesn't limit overall flex as a whole.
When I put my rear sway bar on it will be attached at the ends with swaybar quick disconects. These are regularly used in front coil over jeeps, other wise those things would sway off a road at 50mph. They had a trucks with a *****'s and Stacey's words was it was scary with out swarbars.
So if you want a rear swaybar and also wheel occasionally. just get quick disconects and disconect the rear while wheeling or for the winter, if the ice issue bothers you. When I install all of this I will also maybe make a bracket the sway bar can be attached to while not in use, if this is done copiuous amounts of pictures will be included.
-Will
Old Feb 3, 2006 | 05:17 PM
  #85
skeeter USA's Avatar
Where did you order your sway bar from may I ask . THANKS
Old Feb 3, 2006 | 05:38 PM
  #86
mlawdawg's Avatar
Gotta love 'em.
Old Feb 3, 2006 | 10:30 PM
  #87
CCRider's Avatar
The best price I found was at www.truckperformance.com $178.14
Old Feb 4, 2006 | 04:38 PM
  #88
I also got mine from www.truckperformance.com.
$178.18 also.
Well I haven't got it yet, but I ordered it from truckperformance.com.
Old Feb 6, 2006 | 09:45 AM
  #89
promax44's Avatar
Got the belltech sway bar installed on a 2wd SCREW. Definitly made a difference in how it feels in a corner, feels flat and planted. I will give it a 2 thumbs up mod. This should be an option from Ford. Call it a handleing package; Lower the 2wd just a little, add 20 in wheels and good handling tires and a rear sway bar. If it was available I would have got it.
Old Feb 6, 2006 | 10:14 AM
  #90
F150 Duke's Avatar
So has anyone actually installed this on a 4X4 with SIDO exhaust?
Duke
