why on earth do I have a wire harness on my coin holder?!
Old Nov 16, 2005 | 10:40 AM
silvacrew's Avatar
this wire plug is for the dealership technitian to use a jumper pin to alternate between engine knock-or-vibration mode. when you drop it off for one it "fixes" one and activates the other ! its all a part of ford investing its capital in the alcoholic beverage industry.
Old Nov 16, 2005 | 10:41 AM
04Lariat05kr's Avatar
Does any body know the part# of the switch and where to get one, Thanks for any help.
Old Nov 16, 2005 | 01:33 PM
02SuperCrew4X's Avatar
Don't tell me you wanna put a 4x4 switch in your dash on a 2WD. Please don't do that?!
Old Nov 16, 2005 | 01:55 PM
Why not? Because I wont be able to use it. It's not like I use that coin holder. Come on there is already one in my Flow thru console.
Old Nov 16, 2005 | 02:01 PM
txnole's Avatar
Why not replace the coin holder with a 12v or something useful? Putting a 4x4 switch in a 4x2 is...well, to each his own.
Old Nov 16, 2005 | 06:05 PM
Here's what I did with my coin holder:
This solves my problem of there not being a satellite radio mount available for my particular tuner. I just made my own, and when the truck is ready to be turned back in, I buy another coin holder for a few bucks, and all is well. End of story....
Old Nov 16, 2005 | 08:21 PM
2004_FX4's Avatar
Since the F-150 has so many options available the wire harnesses will sometimes have connectors to options that you vehicle does not have.
If you have a 4x2 AND have the 4x4 switch connector you cannot buy a 4x4 switch and make anything work.
However:
Two of the circuits are for rear illumination (take a typical ohm meter and find the 12V delta between two circuits). You could tap into these two circuts and use it for a low power application (like a LED or something). As long as it's below 1 amp you should be good.
Old Nov 16, 2005 | 08:40 PM
asinatra's Avatar
Yes sir, captain obvious.
I kept my coin holder and dont have to buy a new one if i get rid of it
Old Nov 16, 2005 | 08:53 PM
ChrisAdams's Avatar
If you put in the switch from the 4x4, you could easily hook it up for some custom application. Lights, DVD, express window drop or raise, etc. It would be a useful switch that blended in with the truck.
I mounted my cell phone there, but I considered a second power tap.
Chris
Old Jan 5, 2020 | 09:58 AM
Silver07's Avatar
Where does the other end terminate?
Originally Posted by Req
The coin holder is really a hole filler on the 4X2's. On the 4X4's the 4-wheel switch goes in that hole. During assembly of the 4X2's the wire harness is put in anyway. This is the wire that is attached to the back of the coin holder. If you want to remove the coin holder for any reason just detach the wire and wrap some friction tape around it and stuff it up in the wiring somewhere.
I have the plug on the back of my coin holder too.
I was curious where the other end terminates. Maybe it's buried in the wiring harness and inaccessible?
If it came out in some convenient area, I could possibly put an accessory on the other end.
Old Jan 6, 2020 | 08:08 PM
joe51's Avatar
Originally Posted by etrevino103186
haha! I'll give you credit for being so creative
He should have been a used car salesman.
Old Jan 29, 2021 | 11:14 PM
Fifty150's Avatar
Now that the truck is 15 years old, I finally decided to install USB power ports. Modern consumer electronics are using the "quick charge" USB 3.0. 5V 3.1A
