Need 3 TSB #'s and Details Please
Old Oct 31, 2005 | 08:29 AM
quackrstackr's Avatar
Originally Posted by Ayresusn
I read other places on this board that it is 05-12-10, but that tsb is for some car not a F-150. The service advisor showed me the book of tsb's so that I could see for myself.
Try 05-10-12.
That's the one I saw posted here before the text was taken down and it stated 5.4l F-150's with the 4R75E transmission and build date before 4/20/2005. I made note of it for future reference. I have the occasional rearend clunk and sluggishness as well. I'm planning on having the dealer check it out thoroughly at the fist oil change. My '97 bone stock 4.6L would run circles around the truck I have now..... with better gas mileage to boot.
Old Oct 31, 2005 | 08:39 AM
C-17 Pilot's Avatar
Originally Posted by quackrstackr
Try 05-10-12.
quackrstackr is correct. Here's a link to a thread with the info on TSB 05-10-12:
https://www.f150online.com/forums/sh...d.php?t=214378
When my truck was reflashed for a no-start condition and 3-2 downshift clunk, the dealership cited TSB 05-10-12 on my paperwork.
Good luck!
C-17 Pilot
Old Nov 3, 2005 | 12:06 PM
DrPaul84's Avatar
k just got back from the dealer, well 1 out of 3 are done lol, they had to order calipers an rotors...and they had to order the top channel for the rear slider, the water problem was from a kink in the sunroof drain, it would overflow then dump into the truck, so now i wont get pissed on anymore lol, anyway, so far im happy with schultz ford service, really nice service center they got an it was quick, i got there around 9 somethin, truck got on the lift at 10 an i was out by 11...now next time when they actually do work, it might take a long time lol
Old Nov 3, 2005 | 12:19 PM
minus_13's Avatar
That is some sweet service you got there. All the dealers here in Miami assume you are leaving your truck in for a few days, even when you get there at 7:00 am! The dealers and service here are so bad, I am considering dumping the truck. I cannot get warranty work done in a reasonable fashion. I am going to make one more attempt in a few weeks because I won't need my truck for at least a week. The list will be long, and my patience will be short.
Old Nov 3, 2005 | 12:30 PM
goslow's Avatar
Originally Posted by Quintin
Let's be civil about this...
I do believe that in general, the public doesn't really have any business with TSB information. It tends to complicate matters with dealership service departments, not help them.
I have a Dodge car that had a clunk noise in the front drivers side. I looked up the TSBs and found the exact description of the problem and the fix. Two rivets in the body around the driver's side wheel well, to prevent the panels from flexing under asymmetrical situations.
I brought in the car with my description of the problem and a copy of the TSB.
1st time they coudln't find the problem
2nd time I drove with a tech (showed him the TSB) and he heard the problem but said it was a cv joint, new front axle, picked it up still had the clunk
3rd time drive with a different tech (showed him the TSB), said it was the strut tower, new strut/housing, picked it up still had the clunk
4th time drive with same tech as 3rd time with foreman in the back seat, they hear the clunk, I show them the TSB, they were going with the rack-and-pinion and later someone else called and sait there was a TSB that fixed the problem (which was the same one I showed them)
The car was in the shop a total of about a month.
Old Nov 7, 2005 | 01:55 PM
DrPaul84's Avatar
well got em done, took the truck in at 9:11 by 11:30 i had the keys back in my hands, brakes are changed out , net rotors calipers pads, an they fixed the rear window rattle, so far im happy....wish the brake pedal was a bit firmer though
