Power Window Kit
Ham - Just wanted to say thanks for the info, like I said earlier I was looking into the A1 electric life kit but I really like oem better and it seems like it even cheaper. The link you posted simply says window motor and doesnt say anything about regulator but it is all one assembly right? And FYI for anyone else interested, this is a little cheaper - oem window motor
help please
can anyone clear this up I want to order the kit soon. Do I need the regulators and then the separate motors???? I have an 05' STX Supercab and want front/rear doors. Can someone please put a list up of EVERYTHING you need to make this work.
Window regulator and/or motor from http://www.trademotion.com/partlocator/index.cfm?action=getLocatorKeySearch&siteid=318&ch apter=DP2020&catalogid=1&year=2005&make=10&model=F 150[/URL]
switch kit from anywhere right??
and what is a boot and where does it go?? I am confused Thanks
If you are going with factory parts, you will need the left and right side window regulators for the front doors, and also the left and right side window regulators for the rear doors. The factory window regulators come with the motors. Then all you need to buy is a 4 window switch kit from anywhere. The switch kits usually come with all the wiring. That should be the only parts you really need.
The boot is located in the door jamb and allows the wires to pass through from the inside of the truck to the inside of the door.
difficulty??
How hard is it to remove/install the windows?? It's just unbolt and replace right?? and what about the wiring I looked at the diagram and couldn't find anything for that. is it just a matter of splicing and plugging a few wires?? also if I want to just push the button once and have auto up and down is that an additional part?? You guys are a life saver. Also why does ford sell (2) different set ups for the motor and then a seperate regulator for an 05?? This is confusing. About the boot if I already have one in the door can't I just use that?? Thanks again for all your invaluable help.
done!
I just ordered these parts from the website mentioned above (thank you) can someone make sure this is correct?? I am going to go with the Joker switch kit as well. does anyone have the wiring diagram for the windows?? I am pretty retarded when it comes to electrical unless the directions are easy to understand like hooking up a stereo.
Mechanical Catalog - Ford
WINDOW REGULATOR, F150, MARK LT, w/Super Cab, Right, From 4/27/04 - F150 NEW STYLE 2004-06, MARK LT 1 $79.82 $0.00 $79.82
Status: Ordered
WINDOW REGULATOR, F150, MARK LT, w/Super Cab, Left, From 4/27/04 - F150 NEW STYLE 2004-06, MARK LT 1 $79.82 $0.00 $79.82
Status: Ordered
WINDOW REGULATOR, F150, MARK LT, Right - F150 NEW STYLE 2004-06, MARK LT 1 $44.14 $0.00 $44.14
Status: Ordered
WINDOW REGULATOR, F150, MARK LT, Left - F150 NEW STYLE 2004-06, MARK LT 1 $51.36 $0.00 $51.36
Status: Ordered
THanks again, Luke
Status: Ordered
Status: Ordered
Status: Ordered
Status: Ordered
THanks again, Luke
Originally Posted by 04procompLARIAT
Wouldnt it have been cheaper just to buy the truck with power windows already installed?? And has anyone put in a power rear window conversion?
Originally Posted by Luke5181
Do a search for power windows and someone posted a pic of the OEM regulator (motor IS Included)
I see a picture but has anyone made a guide with multiple pictures?
I'd also like to see some pics of installs if anyone has some.
I want to get power windows, but i'm undicided whether to go with Colibri or just buy OEM parts? How much slower do you think the aftermarket kit is?
As far as the wiring goes, do you just need to tap into any switched 12v power source?
Thanks for any info/suggestions on what to get.
