Changing Spark Plugs
Originally Posted by Quintin
I think the steel insert of the plug is reacting with the aluminum head and corroding.
Originally Posted by RUSS04
Quintin Thank you for your reply if any ford tech had a problem I think its not a flaw in the head design but a flaw in the spark plug design Ford needs to correct the spark plug design
I think its a combination of head design and spark plug design, because you cannot have one without the other. I will be very suprised if a redesigned spark plug fixes this without any sort of head work.
Also, changing spark plugs is not rocket science and does not require a ford tech. In fact, it doesnt matter if a ford tech snaps if off or the regular car buff. When it comes to such things as changing spark plugs, what does being a Ford tech have to do with anything? Its not like this requires a skill that only Ford techs possess, its a matter of mechanical know-how, a thing that many on here possess.
Originally Posted by ChrisAdams
Quintin, how about turning the plug one or two turns out, then spraying a good thread solvent (liquid wrench, CRC, whatever), around the plug and letting it settle for a couple hours?
It would trash the plug from contamination but going to this much work and putting a used plug back in wouldn't make a lot of economic sense anyway.
I think that's what I'll end up doing when I replace all of mine. Going back together, I'm putting a light coat of dialectric grease or anti seize or something on the insert portion of the plug. I also found out that the replacement plugs have already upgraded, for what reason, I'm not sure. I'll find out when I get 'em. No one in town had them, had to get them from our supplier out of Atlanta so they should be in my hands late tomorrow evening or Thursday morning.
Thanks in advance
Upgraded, as in during the product cycle, engineering deems that certain parts may be "better" for an application and upgrades the current stock. I haven't got a clue as to how (if at all) they're different. Spark plugs often update over the product cycle though. Hell, I haven't even looked at one of these style spark plugs until I pulled one out of my truck today.
They go for about $17/ea dealer list price. Autolite apparently makes a replacement too, but I haven't compared any of the Motorcraft or Autolite plugs side by side to see if there really is any difference.
Originally Posted by silverbullet5.4
Well the spark plug was designed around the new head design. The plug is a one of a kind. Lets face it, spark plugs are not designed to have forces exerted on them, not just this spark plug.
Originally Posted by kd4crs
Quintin, I think you are on the the right track there. It sounds like a galvanic reaction between the two metals. I remember a science experiment where two pieces of dissimilar metals were clamped together under pressure and over a long period of time they became nearly welded together. This was due to the molecules of the two metals exchanging places with each other. It sounds like this is happening between the spark plugs and the cylinder heads. The electric current of the ignition may even be helping or accelerating this reaction. Looks like I will be pulling my plugs to inspect and clean them before too long.
Hi guys - I found this while Googling for galvanic corrosion - note the stuff I bolded:
Oct 4, 2002
18-8 Stainless steel has no reaction with aluminum. Make sure that your screws are 18-8 type material. Also 300 series stainless will work . Just don't use any 400 series stainless steel as it is magnetic (has higher carbon content) which is the reaction problem.
Bill Trobaugh
- Richmond, Virginia
Jul 16, 2003
While searching for info on galvanic reaction between stainless steel and galvanized steel I found Bill Trobough's comment that 18-8 stainless does not react with galvanized steel. Does anyone know how 400 series stainless reacts with galvanized steel and how they both react with 30 micron anodized aluminium. They will be used outdoors and we would like a life expectancy of 20+ years.
Bernard Warren
- UK
Aug 7, 2003
Go to www.mcnallyinstitute.com/04-html/4-1.html and look at the section an GALVANIC CORROSION. It also has a list of materials and which would be the anodic end and which would be the cathodic end.
Ray, Chem Eng
- Louisville, KY
Also - look here:
The issue is called nobility. The key is, not just metals in contact, but also the presence of an electrolyte - be it water vapour ( non-pure), combustion byproducts, etc.
Aluminum is the worst offender, and 'passivated Stainless steel is the best.
As well, if the sleeve on the plug was Anodized aluminum ( and never sratched), it would also help.
You guys are definitely on to something.
If the PLUG REDESIGN used Stainless Steel for that sleeve, the problem would be vastly reduced, or perhaps even eliminated.. SS (passive) has the highest nobility.
My 2 cents - forgive me, as I'm not that bright.
Grog
Silverbullet5.4 Iam 52 yrs old I know it does not take a rocket science to change a spark plug But it looks like there is a problem with these plugs I have a 2004 f150 lariat supercrew built 9/04 with 5000 miles on it I just read posts and ask questions I have changed plugs on a lot of motors But not on a 5.4 3v
OTC Ford F-150 Spark Plug Socket
• This unique and patented design works on 2004–newer Ford F-150 pickup trucks with 5.4L 3-valve Triton V-8 engines.
• Socket end is 9/16". Soft rubber insert holds and protects spark plug during removal and installation.
• Extension is part of the socket. Easily fits down spark plug tube in cylinder head.
• Socket has 3/8" drive for use with a ratchet or breaker bar.
http://www.handsontools.com/store/sh...ct_id=13967386
this looks like the monkey
This whole situation sounds to me like it's a combination of things. Over torqueing the plugs at the factory, a lack of antiseize as well as improper removal technique. One thing I do to remove stubborn bolts or plugs is to turn the bolt/plug until I feel resistance then STOP, thread it back in and turn it back out. I repeat this process until the bolt/plug has been removed. If your patient, it will come out without breaking. As more of the 5.4's get to the point where the plugs need to be serviced, I'm sure there will be a TSB about this and Ford will develop a solution.
