4x4 Vibration (Lifted)
Old Aug 1, 2005 | 12:52 PM
bushtree's Avatar
Hey everyone,
I have a fabtech lift kit on my truck, and when i put my truck into 4x4 it seems to have a really bad vibration untell i get up to about 30mph then it seems to go away.
I assume this has to do with the front driveshaft?
I though the fabtech kit can with somthing so that this does happen, is that correct? Should i go back to the shop that put my lift on and ask them to fix it?
Thanks,
Nick
Old Aug 1, 2005 | 01:55 PM
KiCk aSs FX4's Avatar
try some stablizers. ive heard they help
Old Aug 2, 2005 | 02:34 AM
bushtree's Avatar
i already have the dual steering stabilizer kit..
It only happens when i flip it into 4x4.
Old Aug 2, 2005 | 09:55 AM
5150steves's Avatar
I just tried the 4H yesterday at different speeds and I did not notice any vibration or noise.
Old Aug 2, 2005 | 09:52 PM
Matt 05'FX4's Avatar
^ 5150steves.........damn that's one good lookin truck! That lift with the rims/tires looks awesome.....especially with the blue!
Old Aug 2, 2005 | 10:32 PM
Tbird69's Avatar
Check the driveline angle. You may have to shim the transfer case to drop it down and bring everything back into line.
Old Aug 3, 2005 | 12:21 AM
STXFX4's Avatar
The front driveshaft has to be modified.
The teeth have to be shaved down on the spline. It comes with very detailed instructions from Fabtech, I even called tech support to see if I could do it myself. Well of course they said I could. Just to take my time and anyone with a dremel can do it. I'll take it to a pro.
Because you still have to have it rebalanced after you shave it down.
A driveshaft place can do it for around 50-100 bucks.
I had my done for 75 with a ten dollar tip and a quart of BUD. Plus he showed me how to do it.
This will elminate the vibration problem.
Old Aug 3, 2005 | 09:53 AM
5150steves's Avatar
Thanks Matt
Old Aug 3, 2005 | 01:21 PM
bushtree's Avatar
so i should take it back to the shop that lifted my truck and get them to fix it for free right? Considering i payed to have the lift installed on my truck, i didnt pay for them to sick the steps they didnt fell like doing...
Old Aug 3, 2005 | 01:58 PM
STXFX4's Avatar
I would ask if they performed that service and then ask who rebalanced the front drive shaft if they say they did the work. Typically only a driveline shop has the equipment to balance a shaft.
Hope this helps.
