Leveling Kit Problems-Ford Techs. & Others
Old Jul 28, 2005 | 01:57 PM
  #46
RED WING NUT's Avatar
Originally Posted by minus_13
Kudos for the good memory...
Not my memory. 30 seconds worth of work with the search feature.
https://www.f150online.com/forums/sh...d.php?t=178837
Old Jul 28, 2005 | 02:16 PM
  #47
minus_13's Avatar
So you're looking through my previous posts, huh? Stalker...
Old Aug 1, 2005 | 04:47 PM
  #48
heff80's Avatar
minus, did you ever post the pics? i'm considering a leveling kit for the 04 XL i just got. i'd like to see where the wear was and how bad. thanks
Old Aug 1, 2005 | 08:06 PM
  #49
poptop's Avatar
dont worry about your cv joints they can handle the increased pinion angle from the leveling kit look at an atv they have cv joints that run at twice the angle of our trucks with no problem other than normal wear and tear
Old Aug 2, 2005 | 10:34 PM
  #50
jimmyb04stx's Avatar
What kind of wear are you getting, I have the daystar 2.5 and no problems, nothing hits, truck rides fine, angles arent bad at all! Was this kit installed properly?
Old Aug 2, 2005 | 11:42 PM
  #51
ThumperMX113's Avatar
Ditto!
Old Aug 3, 2005 | 02:33 PM
  #52
Anyhow, wait until I post some pics... you might have some nigthmares as well...
It's been a week. Where are these pictures of all of this terrible wear?
Old Aug 3, 2005 | 04:05 PM
  #53
heff80's Avatar
from what i can tell, from looking under my truck, is a 2-2 1/2 inch lift isn't going to change much of anything, as far as angles go. to me,on my truck, it almost looks like the half shafts are angled up a bit anyway. i just don't see how there could be any bad long term effects on the cv joints. personally, i'm going to go with the solid aluminum spacer. i think the only wear that could happen would be from using the two piece urethane spacers...which will eventually crack, especially from having the coil pushed up against the lower piece. but i still wanna see the pics
Old Aug 28, 2005 | 02:37 PM
  #54
...I will be posting pictures of unsual wear on the lower control arm and coils...
Old Aug 28, 2005 | 04:50 PM
  #55
freekyFX4's Avatar
I pulled the kit out yesterday, and I am glad I did. I will be posting pictures of unsual wear on the lower control arm and coils. I am glad I made the decision I did. The truck clearly handles better and the turning radius is much improved. Those of you who think it still has the factory ride with a leveling kit installed should come drive my truck to do a comparison. Completely different truck... Denial is not just a river in Egypt. Good luck to all of you who leave it in there... I am glad mine is out.
Did you bother to get your front end aligned when you installed the kit? If not, then that's why your truck handled like crap. Installing a levelling kit causes the front end to get really "towed out" meaning that the front tires are aimed away from each other. Mine was so far out after the kit was installed, the alignment tech came into the waiting area and asked me if I had done something to the front end recently before he even started aligning it. After the alignment, which brought everything back into spec, the truck handles just like it did before the kit was installed. All manufacturers of levelling kit specify that the truck should be aligned once the kit is installed. If you did get it aligned when you installed the kit, you better go get it aligned again...your front tires are pointing inward toward each other now...
Nevermind...I see that you did have it aligned...now take it and get it aligned again.
